Between The Seats 'E'
Topics | Replies | Author | Views | Last Posts | ||
Help! Newly installed 200 sputters out at 50mph every time. 1, 2 | 27 | Hillbilly | 1473 | Tue Nov 21, 2017 7:15 am by Hillbilly | ||
Anyone know basic air/fuel mixture setting on a Holly 1940? | 2 | Hillbilly | 565 | Mon Nov 13, 2017 6:13 am by Hillbilly | ||
Engine grounding. Important? | 2 | Hillbilly | 575 | Sun Nov 12, 2017 9:12 pm by Hillbilly | ||
Accelerator Cable | 4 | cole63 | 1113 | Sat Oct 28, 2017 2:23 am by cole63 | ||
1961 E-100 bushings | 3 | Zonk 1/75 | 939 | Fri Oct 06, 2017 6:51 pm by 66ThunderVan | ||
window rubbers on a 66 super van | 3 | tikiwagon | 646 | Thu Oct 05, 2017 8:17 pm by Seth G | ||
6cyl head/intake modification ? | 1 | Falcon Guy | 675 | Fri Sep 15, 2017 7:43 pm by Seth G | ||
Lapel Pin on eBay | 1 | Zonk 1/75 | 581 | Sat Sep 09, 2017 10:56 am by Zonk 1/75 | ||
HEI Module | 2 | Seth G | 820 | Mon Sep 04, 2017 12:22 pm by Seth G | ||
Driveshaft question? | 4 | Vangoat | 787 | Fri Jun 16, 2017 4:55 am by Wolfster | ||
Engine/doghouse wiring harness | 4 | Eric Howard | 959 | Tue May 30, 2017 12:54 pm by jdlaugh | ||
Emblem nuts? | 1 | Canada17 | 641 | Tue May 16, 2017 5:55 am by Vantasia | ||
Front spring bushing replacement | 1 | jdlaugh | 712 | Sat May 13, 2017 7:39 am by Irons | ||
Defroster vent nozzle option | 19 | Linoman | 3953 | Mon May 01, 2017 6:53 pm by jrdunn96 | ||
Distributors+Oil Pumps+ Earlies | 7 | DaGroats | 659 | Sun Apr 30, 2017 10:27 am by DaGroats | ||
61 econoline wire harness | 18 | Cdcracing | 2124 | Sat Apr 29, 2017 4:10 pm by Zonk 1/75 | ||
wiper switch | 2 | mechaniman | 769 | Tue Apr 25, 2017 12:36 pm by mechaniman | ||
Transmission gaskets and seals rehab | 0 | jdlaugh | 398 | Tue Apr 25, 2017 9:13 am by jdlaugh | ||
Conversion to Electric Windows / Shaved Handle Door Poppers | 0 | Zonk 1/75 | 585 | Sun Apr 09, 2017 4:51 pm by Zonk 1/75 | ||
Need an e-brake handle pic showing the spring | 7 | Strato1 | 800 | Tue Mar 14, 2017 12:26 pm by Strato1 | ||
Trying to post pics of my van | 20 | TBukit | 853 | Fri Mar 03, 2017 7:29 am by TBukit | ||
Distance front seat bolts? | 0 | Vancy65 | 534 | Wed Feb 22, 2017 5:14 pm by Vancy65 | ||
engine identification | 13 | Nieuwlaat | 847 | Mon Feb 20, 2017 11:56 am by Nieuwlaat | ||
looking for sugestions on the interior floor for my 66 | 6 | vkarppinen | 1031 | Fri Feb 17, 2017 4:13 am by Guest | ||
Gear ratio for a 9 inch | 7 | cole63 | 774 | Wed Feb 15, 2017 5:35 pm by cole63 | ||
Shift arms still hanging up | 6 | Strato1 | 746 | Tue Feb 07, 2017 5:20 pm by Strato1 | ||
Automatic Column Conversion | 2 | mybuells2 | 887 | Tue Jan 17, 2017 6:04 am by mybuells2 | ||
D&D Disc Brakes with 67 master cylinder | 0 | Casimier | 794 | Tue Jan 10, 2017 1:49 pm by Casimier | ||
Autometer Gas / Fuel Gauge Reading Incorrectly | 1 | 66e100pu | 914 | Tue Nov 22, 2016 10:56 am by Baczek | ||
looking for a link for axle bolts | 2 | vkarppinen | 620 | Wed Oct 26, 2016 3:41 pm by vkarppinen | ||
The Devil is in the detail | 3 | vkarppinen | 674 | Sun Oct 23, 2016 6:25 am by bugman | ||
Need source for motor mounts | 9 | jrdunn96 | 1059 | Tue Oct 18, 2016 6:43 pm by Seth G | ||
Broken rocker arm stud | 1 | cole63 | 452 | Tue Oct 04, 2016 8:37 pm by Seth G | ||
Engine running on or "Dieseling" when shutting off? | 2 | cole63 | 701 | Wed Sep 28, 2016 11:57 am by cole63 | ||
SHIFTER Ideas ? | 17 | Oscarm | 2378 | Wed Sep 28, 2016 8:47 am by jifop | ||
changing air cleaner | 5 | hud | 723 | Mon Sep 26, 2016 5:53 pm by Barnabas | ||
LSD rear axle | 2 | jifop | 760 | Sat Sep 24, 2016 1:35 pm by jifop | ||
Electrical bullet connector source and emblem nuts | 4 | jifop | 1021 | Sat Sep 17, 2016 1:44 am by jifop | ||
Broke my driveshaft | 6 | 88hybrid | 707 | Wed Sep 14, 2016 8:41 pm by 88hybrid | ||
Transmission mount .. For swap ... | 16 | AthensTxMc | 1546 | Sat Sep 10, 2016 3:03 pm by AthensTxMc | ||
Correct breather setup | 5 | jifop | 648 | Wed Sep 07, 2016 6:50 pm by Seth G | ||
Overheating issues and vapor lock | 13 | jifop | 978 | Tue Aug 30, 2016 6:29 am by vanny | ||
Got my engine back !!!! CHECK THIS BRAND NEW 50 YEAR OLD BABY OUT | 6 | vkarppinen | 934 | Tue Aug 30, 2016 6:06 am by Vantasia | ||
P.O.R. Paint Over Rust !!!!!! WARNING !!!!!!!! | 11 | vkarppinen | 1823 | Mon Aug 29, 2016 7:50 am by vkarppinen | ||
What spark plugs are people using with the Pertronix? | 4 | Canada17 | 801 | Mon Aug 22, 2016 6:49 pm by Seth G | ||
Belly pan drawing | 5 | jifop | 896 | Mon Aug 15, 2016 11:57 pm by DennisStuy | ||
Overheating .. big time!!! Need to sell a few things and need a few .. | 6 | AthensTxMc | 649 | Mon Aug 15, 2016 7:00 pm by Seth G | ||
flexplate / flywheel questions- how many teeth ? | 7 | vkarppinen | 774 | Sun Aug 14, 2016 6:47 am by econopoor | ||
Sloppy three speed column shifter | 5 | TallGuy | 1772 | Thu Aug 11, 2016 12:03 pm by Vantasia | ||
Falcon Six Cam Advance Question | 5 | jrdunn96 | 622 | Mon Aug 08, 2016 7:56 pm by Seth G |
Sort
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
