changing air cleaner
hud
Number of posts : 23
Registration date : 2012-03-05
Post by hud on Thu Sep 22, 2016 9:52 am
Hi Y'all , I have a 240 motor with a oil bath cleaner. would like to change to paper air cleaner. runs rough with bath cleaner, i took it off and it ran good. where can i get a paper air cleaner from and what kind would be the best for my motor? THANKS, Hud
Number of posts : 1927
Re: changing air cleaner
Post by Barnabas on Thu Sep 22, 2016 4:12 pm
Do a search here. Some have cut open the oil bath housing and installed a paper element, others have found aftermarket air cleaners,, and some of us like the oil bath air cleaner.
Number of posts : 316
Post by jrdunn96 on Thu Sep 22, 2016 4:18 pm
Barnabas,
Is it possible that hud's carb is running in a "borderline rich" condition? That installing the air cleaner is putting it in a choke condition? Just thinking out loud. I had a four wheeler that absolutely wouldn't run without the air filter installed.
Jim
Number of posts : 9274
Post by vanny on Thu Sep 22, 2016 5:28 pm
Hit the search tab at the top of the page and search on bath and I believe the first thread that comes up has pictures with instructions on doing that. It also tells you which filters will fit afterwards.
hud
Post by hud on Fri Sep 23, 2016 9:16 am
got it! thanks for all the info
Post by Barnabas on Mon Sep 26, 2016 5:53 pm
jrdunn96 wrote:Barnabas,
Jim
It could be the oil bath filter screen is clogged with crud. Might just need a good cleaning. There should not be a big difference between filter and no-filter.
    Current date/time is Thu Feb 22, 2018 1:04 am
