Engine/doghouse wiring harness
Eric Howard
Number of posts : 11
Registration date : 2017-05-27
Post by Eric Howard on Mon May 29, 2017 5:58 pm
My name is Eric. My electrical harness from the doghouse burnt up. Can't find a after market one. I'm sure there out there. I don't know much about this kind of electrical problem. Kinda new at this. If anyone has any recommendations it would help me alot. Thanks
Number of posts : 1305
Re: Engine/doghouse wiring harness
Post by uante on Mon May 29, 2017 9:09 pm
http://vintage-vans.forumotion.com/t51186-wiring-harness-help?highlight=harness
There has been several posts about harnesses. Here's one I found using the search tab at the top and looking for Harness. Hope this helps.
jdlaugh
Number of posts : 245
Post by jdlaugh on Tue May 30, 2017 5:09 am
Are the wires in the doghouse still there and hooked up? You can just replace them with wire from your local parts store. Go under the floor, find where they are still good and splice in new wire of the same gauge. Fortunately the wiring of these vans/trucks is pretty simple stuff.
Here's a wiring diagram for the engine compartment. Right click and save or copy to your photo software to see the full image:
Eric Howard
Post by Eric Howard on Tue May 30, 2017 12:05 pm
Sorry forgot to mention my van is a 1965 Chevy van g10 6cylinder. Thanks for the reply. I've been reading the posts before I joined. Y'all are super helpful and polite I appreciate your help
jdlaugh
Post by jdlaugh on Tue May 30, 2017 12:54 pm
Eric Howard wrote:Sorry forgot to mention my van is a 1965 Chevy van g10 6cylinder.
You might want to post this in on the Chevy side. Between the Seats "e" is for help with Econolines. Good luck!
    Current date/time is Thu Feb 22, 2018 1:00 am
