Im in the process of repairing rust damage on the floor . Im not sure what to use after al the metal work is finished. I have used POR on the under carriage but not sure how that would be on the inside. I have seen a por product that is more like a bed spray material which is what im thinking of using . Any ideas or experiences would be great . Thanks all, Vin
looking for sugestions on the interior floor for my 66
vkarppinen- Number of posts : 119
Registration date : 2015-08-28
- Number of posts : 2086
If you want it done with bedliner you could take it to someplace that does LineX or similar and have them spray it. That stuff is amazing.
- Number of posts : 2011
Some have had great results with a bed liner. Usually done across floor and up wall to top of wheel well. No real need to go higher.
Bed liner is great if you are going to put plywood and/or carpet on the floor. The bed liner keeps the floor from secretly rusting away.
cole63- Number of posts : 90
I just recently sprayed the inside floor of my van. I used a kit called raptor liner. Kit comes with a gun to spray it with. It's a two part system with hardener. Easy enough to spray and you can adjust air psi and distance to get desired texture. I bought my kit off amazon.
How much was the whole kit?
Rick's 66 Chevy Van wrote:How much was the whole kit?
Wanna say under $200. Amazon has several different kits to suit your needs.
Barnabas wrote:Some have had great results with a bed liner. Usually done across floor and up wall to top of wheel well. No real need to go higher.
Curious to know why you suggest plywood or carpet over the bedliner. I plan to roll bedliner over the front floor of my A pup and just use small rubber floor mats on each side. Also want to roll it in place of the headliner on the inside of the roof. The rest of the interior will be white paint with black painted trim.
Appreciate any input before I do this.
