Broke my driveshaft
88hybrid
Number of posts : 14
Registration date : 2015-11-12
Broke my driveshaft
Post by 88hybrid on Wed Sep 14, 2016 1:56 pm
I broke the slip yoke Driveshaft on the trans side. My van is a 1965 heavy duty. It has a small u joint on trans side , (that is no longer available from what im told) and a standard 3110 u joint for the 9 inch rear side. I got a replacement off ebay from a 1966 Falcon van, but the shaft is much bigger in diameter, and has the same side u joint. I cannot find info on what van had these larger shafts. I found another but it has the two same size small u joints! for I guess the standard vans with smaller engines. Im frustrated. A driveshaft rebuilder said he could not fix mine as the parts are obsolete.
Can anyone give me some advise, or check there parts bin to see if they have a rear trans yoke from this "larger" ujoint, or a heavy duty shaft with the different size joints. I cant drive my van and I just restored it, and would love to drive it!!
Number of posts : 1366
Re: Broke my driveshaft
Post by uante on Wed Sep 14, 2016 2:09 pm
I don't know any info about drive shafts...I'm sure someone can help though. I am curious about your No Door project, would like to see more about it, pictures and such.
Number of posts : 1741
Post by econopoor on Wed Sep 14, 2016 2:18 pm
The easy fix is to get a rear yoke from a 65-67 big six trans. It will replace the small yoke on your small six trans. Trouble is finding one of these. You might check with a 4X4 shop and see if they can provide one.
Duane
88hybrid
Post by 88hybrid on Wed Sep 14, 2016 2:19 pm
I just posted another thread with the build photos
here they are again
http://s707.photobucket.com/user/88hybrid300zx/library/1965%20Econoline%20Crush
88hybrid
Post by 88hybrid on Wed Sep 14, 2016 2:20 pm
econopoor wrote:The easy fix is to get a rear yoke from a 65-67 big six trans. It will replace the small yoke on your small six trans. Trouble is finding one of these. You might check with a 4X4 shop and see if they can provide one.
Duane
I hope I can find one! It seems they could have been on a mustang or truck f100?
Number of posts : 1935
Post by Barnabas on Wed Sep 14, 2016 7:06 pm
In case it helps, here is a list of all of the driveshafts for our Econolines.
http://econoline.org/driveshafts.shtml?s=id
88hybrid
Post by 88hybrid on Wed Sep 14, 2016 8:41 pm
Thank you for the help. I located a rear trans yoke from a 240 trans! Paid for and on its way! Hopefully it's all I need
    Current date/time is Mon Jun 18, 2018 9:56 am
