Engine running on or "Dieseling" when shutting off?
cole63
Number of posts : 90
Post by cole63 on Wed Aug 03, 2016 4:21 pm
I have a fresh 300 with a 240 head that I've recently got going. The engine starts and runs fine, but when I go to kill the engine it wants to continue to run on. I have checked the ignition switch and power to coil. (no power with switch off) I adjusted timing and carb, but still happens when it is hot. Just trying to get some ideas on what to try next? Thanks, Cole.
boogieman
Number of posts : 69
Registration date : 2015-10-12
Re: Engine running on or "Dieseling" when shutting off?
Post by boogieman on Wed Aug 03, 2016 5:18 pm
id recheck timing, a retarded situation caused my 250 chevy to do the same...although there was also a noticable loss in power and the engine ran hot as well..
cole63
Post by cole63 on Wed Sep 28, 2016 11:57 am
I almost forgot I had made this post a while back. I solved my issue by lowering my idle speed. I also had the accelerator cable too tight and it wouldn't idle back down after letting off the gas.
    Current date/time is Mon Jun 18, 2018 9:57 am
