+21
Vanadian
Sporto's 67
ChevyVanMan1
63chevyvan?
gotavan
mo_1040
wdaguy
25 posters
    disc brake conversion kits????????????? expert opinions?
    Number of posts : 12248
    disc brake conversion kits????????????? expert opinions? - Page 5 Empty Re: disc brake conversion kits????????????? expert opinions?
    Post by donivan65 Thu Jun 11, 2009 8:46 am
    So lets grab some information off the K5 calipers hanging on the TransAm brackets for wheel size and rubbing. Take a straight edge, place it on the side of a stud, against the flange and take two measurements. We are looking for how far the caliper sticks out and up from that particular point. And do it for the 3rd Gen caliper,,,,,,maybe one of those has more clearance and gives us a better choice on what rims we can use that won't rub the calipers......
    disc brake conversion kits????????????? expert opinions? - Page 5 K5_cal10
    wdaguy
    wdaguy
    Number of posts : 157
    Registration date : 2009-02-10
    disc brake conversion kits????????????? expert opinions? - Page 5 Empty rotor -caliper distance??
    Post by wdaguy Thu Jun 11, 2009 9:08 am
    with T/A rotors and 85 k5 calipers theres iquite a gap the rototr is just under an inch and the gap between pads is 1 3/8 no fluid in it. is that normal? I was trying to avoid this, hence all the questions, Napa sold me calipers about the size of a fist, 85 k5 wouldnt line up to bracket. Carquest sold me 85 k5 about 10 inches and they line up. just thinking the gap is loose. Hubs fit to the rotors no mods needed just lugs.
    Post by donivan65 Thu Jun 11, 2009 10:20 am
    Lets dig into those K5 Blazer calipers a little deeper,,,,,,,Here is the ORIGINAL SET UP with 3 rd Gen calipers,,,,,now I want to know,,,,why,,,,,you guys broke the law and put Blazer Calipers on your TransAm rotors,,,,,,,,
    disc brake conversion kits????????????? expert opinions? - Page 5 M1dadi12
    disc brake conversion kits????????????? expert opinions? - Page 5 M1dadi13
    disc brake conversion kits????????????? expert opinions? - Page 5 M1dadi14
    Post by Digz Thu Jun 11, 2009 4:33 pm
    Yes , the K5's seem to have a lot of gap without any exstension on the caliper piston. I raised my eyebrows at that also. I'm curious as to what runs out first ,the pads or the piston. The K5's use a 3/8 bolt on the brake hoses, I am under the assumption that the 3rd gens use a 7/16. I believe the 3/8's may open up a better hose selection without drilling out the hose ends as was mentioned in one of the "how-to" scenarios. Is is possible the K5 rotors are originally thicker? Is there a difference in measurement between the "ears" on the 3rd gen and the K5 calipers?
    Post by donivan65 Thu Jun 11, 2009 5:38 pm
    Now thats what I am talking about,,,,,what did you use and why,,,,,,I just want the facts so WHEN the next guy walks in and says " anybody here ever put front or rear disks brakes on an EARLY Chevy or GMC Van, he has LOTS OF CHOICES to choose from. And you just might end up inventing a new rule in the process,,,,,,,,,,I really like people that try different things,,,,thats called,,,,,,,,PROGRESS.....
    Post by Digz Thu Jun 11, 2009 6:50 pm
    well ,by the on-line specs I have found the rotors are the same thickness. This is going to take me to the brake pads ? I bought the K5 pads to go with the calipers. A thicker outer pad would re-center the caliper better. its hard to tell in the pic but the caliper is already positioned over the allen bolt. Might be a good idea to go shopping again and see if the 3rd gen pads are thicker.
    disc brake conversion kits????????????? expert opinions? - Page 5 05230914
    Post by donivan65 Thu Jun 11, 2009 8:19 pm
    Ok,,,so you are not digging how those K5 pads sit,,,,,,so lets check it out,,,,,,you just know as the outer pad wears, the caliper wants to walk off the end of the bolt. And that might mean that the bracket is out too far,,,,,but lets start with the EARS,,,,,how wide is the throats of the K5 and the 3rd Gen calipers??? We basically got a contest comparing the K5 and the 3rd Gen calipers going on here,,,,,
    disc brake conversion kits????????????? expert opinions? - Page 5 Workin14
    disc brake conversion kits????????????? expert opinions? - Page 5 Workin15
    disc brake conversion kits????????????? expert opinions? - Page 5 Workin16
    Post by donivan65 Thu Jun 11, 2009 8:27 pm
    So basically,you don't have the K5 riding where it belongs like in this 3rd Gen picture????
    wdaguy
    wdaguy
    disc brake conversion kits????????????? expert opinions? - Page 5 Empty lines today
    Post by wdaguy Fri Jun 12, 2009 5:54 am
    I hope to run lines today.. Most of my time is returning inncorrect parts. I mentioned this before I started, every part I got at Napa was wrong sept for the hand soap... I think when I say 65 the computor goes to 67?? I ordered a Griffin radiator called to check, 19x24 ..5 weeks later, 27x25.. so cut out a 2nd gen doghouse add crossmember, move sway bar connect electric and hoses to doghouse repaint.. all beacause of wrong part??/ I just returned it.
    Number of posts : 7905
    Post by DanTheVanMan Fri Jun 12, 2009 6:05 am
    Yes, it is truly a learning and trial & error experience!!!! And Wdaguy, we've all done it, still are and always will be doing it as long as we have earlies. That's why it's called a "Labor of love" thing.....
    ** Great pic's Don!!!
    disc brake conversion kits????????????? expert opinions? - Page 5 Qr_cod10
    wdaguy
    wdaguy
    disc brake conversion kits????????????? expert opinions? - Page 5 Empty help on my space
    Post by wdaguy Fri Jun 12, 2009 1:04 pm
    I went out and got 75 g10 caliper..almost a twinn. but same problem the inside pad is riding on the rotor but the outs ide is flapping aaround..maybe 1/4 of play.. It seem like the rotor needs to go out? or caliper move inward toward engine? Any ideas??
    wdaguy
    wdaguy
    Post by wdaguy Fri Jun 12, 2009 1:17 pm
    disc brake conversion kits????????????? expert opinions? - Page 5 Vincentvango007-3
    disc brake conversion kits????????????? expert opinions? - Page 5 Vincentvango010-2
    wdaguy
    wdaguy
    Post by wdaguy Fri Jun 12, 2009 1:20 pm
    tdisc brake conversion kits????????????? expert opinions? - Page 5 Vincentvango010-2ry that again see inner pad rubbing outter is way off whats up?
    wdaguy
    wdaguy
    Post by wdaguy Fri Jun 12, 2009 1:25 pm
    disc brake conversion kits????????????? expert opinions? - Page 5 Vincentvango009-3
    Post by donivan65 Fri Jun 12, 2009 2:23 pm
    Well for 1 thing it aint in until you bleed the brakes and pump the pedal until the piston pushes the inner pad into the rotor which also pulls the outer pad into the rotor,,,,,THEN its in,,,,,,and you see where everything ends up,,,,,,,
    wdaguy
    wdaguy
    Post by wdaguy Fri Jun 12, 2009 2:39 pm
    that pad shouldnt be flapping around? and the other fitting sug? I am thinking with fluid its going to get worse??No? Anyway is there shimming or spacers needed? I am thinking maybe I did the bushings wrong so the rotor is is in too far? You are the boss I am just a painter.
    wdaguy
    wdaguy
    Post by wdaguy Fri Jun 12, 2009 3:54 pm
    I bought both 85 blazer and 75 g10 calipers..hard to tell the difference same issue with the pads.
    Post by Digz Fri Jun 12, 2009 8:03 pm
    I'm thinking it is going to be the nature of the beast, we are adapting parts not intended for our vans . I took mine apart agian today just to get another look and it will work as is. just not quite like one would like to see it maybe. the distance between the ears is the same 3", the only thing I can see to change the location of the caliper on the guide sleeve would be to space the rotor out a little further from the hub, but this wont change the gap in the pads, only thicker pads would do that. looks like the caliper piston will have to make up about a 1/4" like ya said WDA.
    Also the ears on the brackets are very tight on the calipers , they need to be ground out so the caliper slides easily thru, (not even sure mine are good enough yet) if it gets warm it might sieze alittle. I have almost as many credit slips as part slips from the auto parts store, those guys at the parts counter have been very patient with me Mad for the most part . Next thing I have to sort out is longer front shocks that are not fatter, Strike one there so far.
    Number of posts : 1778
    Post by m1dadio Fri Jun 12, 2009 8:32 pm
    I just wrote a huge post about whats going on for you and the %$# thing disapeared when I went to post it.
    I would like to help out here.
    The brackets should have a 3/8 offset.
    You might have a wheel bearing or hub problem.
    tell me what bearings, hubs, rotors and calipers you are using?
    Bolt the rotor to the hub and push the caliper in so the outside pad is up against the rotor then lets see a pictture of were the caliper eyelets sit on the slide pins. They should be about 1/16" from the brackets. dont worry about how loose the inside pad looks, that will go away when you punp up the pedal.
    I am suprized to hear you say the rotors fit right onto the hubs, something aint right there. So far all 40 + installations have had to do a little re-work to the hubs.
    What pads are you using? the more expensive pads are thinner. Get the cheep fully organic pads they are thicker.
    The 79 trans am rear disc brake rotors are slightly thinner then the rotors used with those calipers.
    The "K5" and the other calipers( same for novas, c series, g series 1/2 ton trucks (all) and most full size GM cars from about 70 to 78 )are all the same, the only difference is how the brake hose attaches. The all take the pads that have the basic part number of "728".
    Those other calipers DONIVAN is measuring are from aN "S" series vehicle or rear calipers from alot of cars. They are the smaller calipers that take the pads with basic number 7070.
    M1D
    Number of posts : 378
    Post by xjamesx Fri Jun 12, 2009 9:11 pm
    not to interject but i did NOT need to do any work to my hubs to fit the rotors using this setup with same rotor and calipers, etc.
    so i guess that would make 2 installs without any hub work needed.
    although i did expect to since everyone else needed it....
    james
    Post by m1dadio Fri Jun 12, 2009 9:47 pm
    Well like my instructions said this is a frankenstien set up so no two vans will be the same.
    as I recall There is an inner bearing race that will fit the hub but the bearing will sit about an eight of an inch lower and that will sit the rotor in that much further. I will have to consult my old research if I can find it. But I bet the problem has something to do with the inner wheel bearing.
    Hey WDAGUY when the hubs installed does the nut land in the right sport just over the cotterpin hole when only one washer is used?
    m1d
    Post by m1dadio Fri Jun 12, 2009 10:04 pm
    whenthe rotor and bracket are mounted it should have clearance like this
    disc brake conversion kits????????????? expert opinions? - Page 5 Dscn0314
    disc brake conversion kits????????????? expert opinions? - Page 5 Dscn0315
    Why wont the pictures post?
    M1D
    wdaguy
    wdaguy
    Post by wdaguy Sat Jun 13, 2009 6:44 am
    Thanks for the help M!, always hate to bother you..
    I went in another direction at first but have returned to the 81 T/A rear rotors
    75 g10 calipers with 35.00 pads
    with no fluid, the inner pads got 1/8 gap to disc
    the outter has a good 1/4 gap or more and is rattling around freely.
    I am concerned that when pumped up it will take a lot to get the outter engaged.
    Bushings hubs ...did I do something wrong.. removed the stock hub ..had outter washer and small bearing but just the ball bearing part of the 2 part bearing.
    Rear larger bearing only the ball bearing part was used and then a oil seal which layed flush to the hubs edge. this bolted back up is 1/8 inch from end of spindal. The hub sticks through the rotor about 1/4 of an inch..
    I dont see how I could move the rotor out?
    Sorry the hub went into the Nova rotors and the Trans Am with out any grinding. Making the master fit was a pain and then finding odd ball lines adapters is still going on right now. I will post more photos. I can check on cheap-thicker pads today. I dont do this for a living. So I dont know if the outter pad could be shimmed in or caliper spaced out toward the engine or maybe I am just worried about nothing? Keep me posted I respect your opinion Thanks Geoff
    wdaguy
    wdaguy
    Post by wdaguy Sat Jun 13, 2009 6:50 am
    [size=18]The cotter pin did line up It could be one extra turn in more than befor.. I only replaced what I saw when I took it of. thought the 2 new bearing came in two parts the hub only excepts the angled part and a oilseal on rear..correct?[/size]
    Post by m1dadio Sat Jun 13, 2009 7:59 am
    If you really have 1/8 and 1/4 gaps something is not rightThe gaps you are describing sound eccesive; Are you sure you have the right rotor? it shoulkd be almost an inch thick. I will take some more pictures of mine today.
    http://vaninmag.homestead.com/discbrakeinstall.html
    What bearing part numbers are you using? did you change the cone in your hubs? The cone is the angled part you have to press in and out of the hub.
    The only shimming of the brake pads is an anti noise pad the comes with some pads.
    The "good 1/4 or more is a problem as you will loose too much of the guide pin travel when you push the caliper outside pad up against the rotor. Which you can do and show us a picture. The out pad rattaling around is because you did not read the instructions. There is a "Crimping proceedure required that you will do with the pads you are keeping as they will not be returnable afterwards.
    disc brake conversion kits????????????? expert opinions? - Page 5 Dscn0316
    disc brake conversion kits????????????? expert opinions? - Page 5 Dscn0317
    M1D
      Current date/time is Mon Nov 25, 2024 10:52 pm
