+14
rustyspoke66
SnarkyPoet
A100 Wrench
rebar
18 posters
    new engine
    Number of posts : 2036
    new engine - Page 7 Empty Re: new engine
    Post by dodge man Wed Dec 11, 2013 12:40 pm
    theres no way to make a chevy cruze to look that good, lol i wont tell her that, yeah dix the outside of that pully is 7'' i hope that helps you
    Number of posts : 8770
    Post by dix Wed Dec 11, 2013 1:10 pm
    John what did you do for the carb linkage hook up ??? Can't tell from the photo's
    Post by dodge man Wed Dec 11, 2013 1:35 pm
    i ued the stock linkage, only thing i had to shortin the rod that goes to the carb, i just bent it so it would be shorter, its stiff enough that it wont bend back and i have full throttle now, the next time i'm out in the garage i'll take  a picture of it, also i have plenty of room for the air cleaner, i sat the sides of the dog box were they will sit and i can see the cleaner wont hit the lid, i want to leave the dog box off so i can make any adjustments and check for leaks on the first test drive, i'm sure i'll have to adjust the transmission kick down rod again,
    Post by dix Wed Dec 11, 2013 2:07 pm
    John once you get the dog house reinstalled put a paper cup on top of the aircleaner, close and latch the lid, and then open it to see what you end up with.
    Post by dodge man Wed Dec 11, 2013 2:41 pm
    i want have that much room, lol but at least 2 or 3''
    Post by dix Wed Dec 11, 2013 3:47 pm
    What i ment was close the lid and the cup would crush down onen the lid and you know what you have..
    Post by dodge man Wed Dec 11, 2013 4:06 pm
    should the cup be full ?
    Post by dodge man Wed Dec 11, 2013 4:31 pm
    LOL yeah thats a good idea, i'll let you know how it turns out,
    Post by dix Wed Dec 11, 2013 5:20 pm
    fill it with green paint
    Post by dix Thu Dec 26, 2013 2:25 pm
    So how's the headers John ???
    Post by dodge man Thu Dec 26, 2013 5:48 pm
    I was going to install the exhaust pipes and mufflers today but I forgot to turn up the furnace in the garage last night and it was to cold to lay under the van, so tomorrow i'll get it done and let you know how it turned out, I still have to adjust everything and test drive it, so i'm excitied to see how it runs, then install the insulation over top the dynamat on the dog box,
    A100 Wrench
    A100 Wrench
    Number of posts : 572
    Post by A100 Wrench Thu Dec 26, 2013 7:45 pm
    Nice work
    Post by dix Fri Dec 27, 2013 1:59 pm
    Here is one for you john...
    new engine - Page 7 Tumblr59
    Post by dodge man Fri Dec 27, 2013 2:07 pm
    YEAH I'LL TAKE THAT ENGINE DIX LOL I GOT THE EXHAUST ALL DONE I'LL TAKE SOME PICTURES TOMORROW. FIRST TEST DRIVE TOMORROW, I HAVE THE PIPES COMMING OUT ON BOTH SIDES IN FRONT OF THE REAR TIRES. I THINK I'LL FIND SOME CHROME TIPS,
    Post by dodge man Sat Dec 28, 2013 1:36 pm
    [img]https://i.servimg.com/u/f58/17/71/57/6[url=https://servimg.com/view/17715767/256]new engine - Page 7 Sam_06107/sam_0710.jpg[/img][/url]new engine - Page 7 Sam_0611
    exhaust all done. the test drive went great, still need to adjust the passing gear rod,
    Post by dodge man Sat Dec 28, 2013 1:38 pm
    new engine - Page 7 Sam_0612
    Post by dix Sat Dec 28, 2013 1:46 pm
    Glad to hear that John,I'm happy for ya...
    Number of posts : 14778
    Post by vanny Sat Dec 28, 2013 2:22 pm
    Man, that is nice and clean under there!! Looks Great and I'm glad to hear everything went well.  cheers
    Post by dodge man Sat Dec 28, 2013 2:30 pm
    thanks guys. I feel better knowing everything is ok with good oil pressure and low temperature and no leaks, with the exhaust it sounds good too, only thing left is the insulation on the dog box, i'll take some pictures of that when i'm done,
    Post by dix Tue Dec 31, 2013 2:00 pm
    John in the page 11 photo it shows the speedometer cable going under the exhaust , it needs to be on top and tied up, it will not last long there...
    Post by dodge man Tue Dec 31, 2013 2:26 pm
    thanks for the heads up on that, I had fixed it right after I took these pictures, I wrapped the shift cable were it goes through the headers with fire foil and then header wrap, after the first test drive everything was A ok,,
    Post by dodge man Tue Feb 25, 2014 1:42 pm
    new engine - Page 7 Sam_0811
    new engine - Page 7 Sam_0812
    new engine - Page 7 Sam_0813
    engine is all done, everything is insulated, I have 2 1/2'' clearance above air cleaner, runs great!!
    Post by Joe Van Tue Feb 25, 2014 2:56 pm
    LOOKS GREAT..Glad to hear All went Well those mufflers will really let that Motor breath... cheers ..
    Post by dodge man Tue Feb 25, 2014 3:26 pm
    thanks Joe, it really sounds good, and not to loud. just waiting for better weather to give her a stretch,
    john
    Post by dix Tue Feb 25, 2014 3:28 pm
    LOOKS GREAT JOHN... whats next ???
      Current date/time is Tue Nov 26, 2024 1:59 pm
