+14
rustyspoke66
SnarkyPoet
A100 Wrench
rebar
18 posters
new engine
- Post n°126
Re: new engine
i'm planing on it VANNY, we want to go to key west then make a big circle around the states, i'll leave the water pipe at home, lol
rustyspoke66- Number of posts : 180
- Post n°127
Re: new engine
If you happen by Spokane, WA. feel free to look me up. I would love to check out your van. I'm looking at two years and taking a trip back to the east side of the U.S.
- Post n°128
Re: new engine
will do, and you do the same,
- Post n°129
Re: new engine
have a problem, someone might know what it is, when i turn the ignition key to start i loose voltage to the plus side of the coil, i checked it at the ignition switch and i have voltage at ign.1 termanel and when i turn the key to the cranking position i loose voltage, the only thing i did was replace the voltage regulator when i put the new engine in, i cant see were that should mater anyways, why do i loose voltage when i turn the key to start ? any help would be greatly appreciated/ john
- Post n°130
Re: new engine
On the ignition switch there are 2 different poles for ignition voltage, Run which goes thru the ballast and Start, which bypasses the ballast. The Start circuit is the one you need to check.
http://www.sweptline.com/tech/68_awire.jpg
- Post n°131
Re: new engine
ok, the red wire goes to ign.1 it goes to the plus side of the coil, shouldnt there be voltage there when im cranking the engine ? i loose voltage to the ign.1 when i crank the engine over, then when i let off the key it has voltage back again, i.m not useing ign.2 sence i did away with the balast. the engine does crank,
- Post n°132
Re: new engine
The switch shuts off power to ign 1 (Run) in Start.
YOU removed ign 2 (Start) so YOU removed the power to the coil in the start position!
- Post n°133
Re: new engine
ok, if i wire the red and pink together it should work? the red is on ign.1 and the pink is on ign.2
- Post n°134
Re: new engine
YES
- Post n°135
Re: new engine
i'll go out and try it now, i installed an electronic unit in the dist. and i thought all i needed was the red wire, thanks rod, again you got me out of a jam,,
- Post n°136
Re: new engine
thanks again Rod, thats what i needed to do, works great,
- Number of posts : 8769
- Post n°137
Re: new engine
Nice job Rod!!!!! Hows in running John ??
- Post n°138
Re: new engine
i havent fired it up yet, still repairing all the wireing to the ignition switch wires were spliced everywere, i want to make sure everythings right so no problems down the road, i may one day rewire the intire van buts not to bad now, my wife bought me mufflers and a universal exhaust kit from summit, but wont let me have anything till christmas, this overhaul was supose to give me something to do all winter '' she says'' but its about all done now, i still want to do some body work but may wait till the rust pokes through i have some bubbles in both rear corners, i think all these A100s rust out there, thanks for asking tho,
BillyBlaze- Number of posts : 114
Registration date : 2013-08-15
- Post n°139
Re: new engine
You could always just rattle the windows with the open header for a minute to bring a smile to your face
- Post n°140
Re: new engine
Joe Van- Moderator 1st Class
- Number of posts : 4619
- Post n°141
Re: new engine
Nice Clean Install LOOKS GREAT it should move the Van along nicely. ..!!!.You will get many trouble free miles out of that motor.............
- Post n°142
Re: new engine
man i hope the motors a good one joe, i'll be fireing it up the day after christmas once i get a pipe on that goes past the trany, with open headers they shoot out right beside the shift cable and neutril switch, and trany cooling lines, thanks guys, john
- Post n°143
Re: new engine
- Post n°144
Re: new engine
- Post n°145
Re: new engine
you can see on the left side i had to cut and bend up the floor 1'' so the headers would clear, i reworked the side panel of the dog box to fit, i desided to fire it up with the open headers and had my wife reach in and turn the key i forgot to tell her it would be loud she must have jumped a foot off the ground,lol anyways it has great oil presure and i was able to fill the trany, waiting for the exhaust then i can test drive it,
- Post n°146
Re: new engine
- Post n°147
Re: new engine
Looks good Dodge man
- Post n°148
Re: new engine
That looks really sweet! Many trouble free miles to come! How bout a trip to Bakers on June 22?
- Post n°149
Re: new engine
The engine looks nice John, The wife wants her's to look that good, Thanks for the pulley info.
- Post n°150
Re: new engine
thanks guys, i'll be going to bakers, cant wait to go, i still need to change that nylon oil line to copper, dont want to chance blowing up the engine over a couple bucks
