    Need 289 engine help
    Number of posts : 864
    Need 289 engine help Empty Need 289 engine help
    Post by Casimier Thu Mar 13, 2014 5:41 am
    Need help with an engine problem...
    Installed the 289 in the Econo with new single pole alternator.
    It will crank and start fine but as soon as I give here gas under load she shudders and shuts down.
    Put a test light to many connections in gear with engine revved and I'm getting blinking on the test light and the engine shudders.
    I'm also getting dischard from the battery.
    The light does not blink in neutral with engine revved.
    I have replaced the fuel filter and solenoid.
    Any ideas?
    Jim in NJ aka Casimier
    Need 289 engine help Empty Re: Need 289 engine help
    Post by Twinpilot001 Thu Mar 13, 2014 5:47 am
    disconnect the alt. retest? also check the ignition 12v feed source on dizzy - when running & then has shutter/-if so the ignition @ dizzy or likely coil 12V + is being interupted. dont know what dizzy u are running?? point type or=??
    Number of posts : 12246
    Post by donivan65 Thu Mar 13, 2014 9:52 am
    ,,,,,,try it with the vacuum advance disconnected,,,,
    Number of posts : 2087
    Post by Seth G Thu Mar 13, 2014 9:24 pm
    How did you wire the alternator +12, to the starter battery terminal? You can rev it up just fine and everything is hunky dory in neutral?  The fact that you are not charging points to a problem with the alternator, maybe. Sounds like a grounding issue, maybe with the alternator when it's torqued by the engine loosing ground or another vital grounding issue if you're blinking 12+ all over and not just in the ignition circuit. Check alternator chassis ground to the block, or add a chassis ground to the block from it, and check battery to block and battery or block to chassis ground.
    Post by Casimier Sun Mar 16, 2014 7:28 am
    Did all of the above. Points are petronix in ford dizzy.
    I'm thinking safety neutral switch is shorting out.
    Anyone have one for a 33 C4 trans?
    Post by Twinpilot001 Sun Mar 16, 2014 7:31 am
    disconnevt the neutral sw & restart -see if runs on -im still betting its  charging syst -or- ignition!! coil wire? have u run this in the dark & watched  all ign parts??  Twisted Evil
    with a FULLY!!!! charged battery - disconect the alternator-all wires- & re test run it -????
      Current date/time is Fri Nov 22, 2024 9:02 pm
