+32
gfleduc
dutchman101
sweetvan
retrogeek
SteelyVan
divisionbrewing
66BC
whalemstr
richie61
busman78
kaz
Denton
Rick's 66 Chevy Van
36 posters
GMC Jacke's van
- Post n°601
Re: GMC Jacke's van
He's a good egg! I'm happy to see that Vanning and Vanners are chipping in and lending a helping hand in trying to keep these gems on the road!
JackeFriend- Number of posts : 940
- Post n°602
Re: GMC Jacke's van
vanny wrote:He's a good egg! I'm happy to see that Vanning and Vanners are chipping in and lending a helping hand in trying to keep these gems on the road!
Yes, I have good Vanners here for sure. I worked on the cosmetic needs today.
I dropped off my belly pan, fins and front & rear sway bars to get powder coated. I think that about is it for the big stuff.
Once the tunnel is completed, I should be good to drive a bit cooler. The 350 should do better with a little breeze hitting it. We will see for sure very soon.
- Post n°603
Re: GMC Jacke's van
- Post n°604
Re: GMC Jacke's van
- Post n°605
Re: GMC Jacke's van
Nice when a plan comes together! Congrats Jacke and Rich! Good teamwork!!!
- Post n°606
Re: GMC Jacke's van
Started the sway bar installation with my new gold powder coated 1st gen front sway bar. Rich was great to work it out...he was sweating like a swami. He had to make shift some fender clips to bolt the clamps up into inside the frame. The cross member addition made it very close he had to cut away some steel to make room.
Next the new powder coated black Belly pan and fins. Here is the fin just unwrapped.
Next week I drive over to Rich for a change! He has been having to visit gravel land too often since my surgery. I re-insulated the Doghouse lid added some exhaust wrap around the areas that touch my leg for extra protection under the heat shield. Put on a new Steel Rubber gasket. They are cut to fit the edge of the lid with grip.
Now I am doing better and the van is doing much better. Off I go into the future
- Post n°607
Re: GMC Jacke's van
Jacke’s van had the holes in the frame for the sway bar brackets but they didn’t have any threads in them. Check out this method I came up with! There are fancier ways to do it. Don did his clever bent threaded rod trick to attach the 2nd Gen radiator support but we didn’t have a lot to work with at Jacke’s place. This contraption just fit into the 3/4” hole in the frame, and reached over the bolts Don had added. It took a little finagling to get one or two of the bolts started but it worked out fine!
- Post n°608
Re: GMC Jacke's van
And now we have yet another way to get the job done! Way to use your noggin, Rich! That should help Jacke go straight down the road and stay cool in the process!
- Post n°609
Re: GMC Jacke's van
So the Belly pan is in place. Dropped it down 2.5" to gain more air flow. Now along with the new tunnel and the drop to scoop extra air, my temperature is running at a nice 180. Thanks to all the
hard work Rich did I was able to drive without a heat problem. I saw a couple vans at the show that had dropped their belly pans, and had good results. Rich and I used our heads to do a nice fit and finish. Trimmed out in black to match the powder coat color. The sway bar is in place and I am glad to not be swaying as I corner at 60 MPH!! LOL
- Post n°610
Re: GMC Jacke's van
That looks Fantastic!!! Nice teamwork and I'm happy to hear that your Hot Flashes are under control! Nice to see you've also got that "burger fan" in place to keep the air circulating around the doghouse!
- Post n°611
Re: GMC Jacke's van
vanny wrote:That looks Fantastic!!! Nice teamwork and I'm happy to hear that your Hot Flashes are under control! Nice to see you've also got that "burger fan" in place to keep the air circulating around the doghouse!
Yes indeed, the burger fan, the tunnel, the scooped front pan... finally the old girl has cooled down
The drive is better because I can relax and not worry about overheating my engine.
I can drive cooler because the exhaust wrap I put inside the edge around the lid, has helped keep the radiant heat from the engine down to just warm.
The van is nearly finished! Just need the new shocks and rear sway bar put on.
samsvan- Number of posts : 672
- Post n°612
Re: GMC Jacke's van
Holy McGyver on the sway bar mounting! I have to ask though, it looks like the way you got them in the frame made the threaded part of the nuts point down. I don't know how much stress will be put on the attachment points but I'm sure you don't want anything coming loose down there.
I dropped the front of my belly pan like you did. Since my front end is lower, I only shimmed mine down about an inch so I wouldn't scrape it off. I'm glad to hear your tunnel and new fan have gotten you rolling with confidence!
- Post n°613
Re: GMC Jacke's van
samsvan wrote:Holy McGyver on the sway bar mounting! I have to ask though, it looks like the way you got them in the frame made the threaded part of the nuts point down. I don't know how much stress will be put on the attachment points but I'm sure you don't want anything coming loose down there.
Yes the sway bar was a challenge to install.
The fender nuts are facing correctly just not slipped over a lip. So they are just sitting inside the frame so the bolts will hold onto something! Although the fender nut is not as strong as the #8 bolt.
But I drive her easy, Rich and Don have both had to do an improvisational creation on attaching to my frame. It is a second gen pan for a start. Second gen cross member to hold the second gen cross flow radiator in a first gen van.
So Don said it wasn't a first gen or second gen... maybe a 1-1/2 gen. LOL
- Post n°614
Re: GMC Jacke's van
Jackie your van is looking great ! How are you doing ? Bill
dutchman101- Number of posts : 107
Registration date : 2013-07-14
- Post n°615
Re: GMC Jacke's van
Jackie its way past the time that I should have told you how impressed I am with your build but life gets in the way so now I am tellin ya wow great job
- Post n°616
Re: GMC Jacke's van
BILLS66 wrote:Jackie your van is looking great ! How are you doing ? Bill
Hi Bill,
How have you been doing? I have been getting stronger. I got my cholesterol down to a total for both of 78. So my heart wont be building up any more plaque. I went through cardiac rehab for a few weeks to get stamina up.
I am enjoying my new found life! The van is almost completed... "that is what they all say"
Thanks for thinking of me. It means a lot
- Post n°617
Re: GMC Jacke's van
dutchman101 wrote:Jackie its way past the time that I should have told you how impressed I am with your build but life gets in the way so now I am tellin ya wow great job
HI,
Well thank you for the koodoos. I have worked very hard to get the van to were it is today. I have had a lot of help from the vanner's in my area too. I could not do it alone, for sure. Being one of the only women driving around is fun. I may be the only one? But, I drive that three on the tree
like I know what I am doing! Thanks again!
- Post n°618
Re: GMC Jacke's van
Got the new Monroe shocks put on.... really needed shocks! Rides much better.
Next gotta finish the rear sway bar installation. I have been reviewing Don's thread. I am doing the exact same thing as he has done and I hope it is as easy as he makes it look! I will see what I can get accomplished this week. The weather is really nice...
- Post n°619
Re: GMC Jacke's van
Jackie I'm doing well.Keep up the good work and enjoy cruising that nice van !
Bill
Bill
- Post n°620
Re: GMC Jacke's van
Glad to hear you are doing well. I have been driving around trying to get some time behind the wheel , the weather is really nice about 84 today. I drove to the beach and the lake near me this week! Everyone was working when I went to the beach today. and there was quiet and the smell of the salt air! Perfect Hope you too get some drive time before winter hits.BILLS66 wrote:Jackie I'm doing well.Keep up the good work and enjoy cruising that nice van !
Bill
- Post n°621
Re: GMC Jacke's van
- Post n°622
Re: GMC Jacke's van
I'm happy to see that you're taking her out and about. At least it's a nice surprise when you forgot what you were driving!
- Post n°623
Re: GMC Jacke's van
Goldie's got a nice stance too!!!
- Post n°624
Re: GMC Jacke's van
- Post n°625
Re: GMC Jacke's van
Nice pic...who took it???
