Thanks for the pixs again and info. They really help someone like me who has a medium understanding and background on this stuff. I am always willing to tear it apart, and what a great feeling when u are finished, knowing u did it. I dont have any grinding tools yet. Removing the studs off the hub might be the hardest part for me. I am in Taiwan right now believe it or not. Coming back next week. Looks like i have a brake job to do.
+27
dirtbag69
polosteve
rustyspoke66
Tang
61v100
BoneMan
counsel62
BillyBlaze
radicalran
jfox
tommyfogarty
KenCashion
lws67
69A108
equium
rebar
white-lightning
agentwilliams
Stoopid john
31 posters
Scarebird brakes
69A108- Number of posts : 39
Registration date : 2012-06-28
- Post n°101
Re: Scarebird brakes
I hate the feeling of going down a hill and having that what if feeling. Maybe be it's just being paranoid, but being a LA Firefighter, seen alot of stuff happen. Sometimes not so good.
- Post n°102
you could have a garage or machine shop press out your wheel studs, or after you cut the studs off close to the drums the studs will then hammer out easy, be sure you check on this sit for all the right parts, after you get your scarebird brackets, everyone is very nice on here and are willing to help, you dont need to mesure what size axle you have any more, scarebird has drilled holes in the plates to fit eather axle size,
- Post n°103
That's what i was thinking too, about the machine shop. You are right, there is some much information here. I read this site everyday. Thanks to people like you and the other i have made many upgrades.
When i get my stuff i will probably checking in with u guys.
- Post n°104
be glad to help any way i can, if not for this site and the guys on here i would not be as far along with my van,
- Number of posts : 8729
- Post n°105
you can hammer the studs out of the hub just make sure you support the hub and don't hammer to hard or you will bend the hub. but it's not hard. rember to oil every thing up a few days ahead to keep things simple.
jkr- Number of posts : 1148
- Post n°106
do your self a favor and do NOT try to press out the wheel studs as you will bend the hub. they are "swedged" in place and a good machine shop should know how to do this. if not find another one. you can do it yourseelf with a hole saw like the pic shows. remove the drill bit from the center and cut around the stud. do all 5 and just drop it on a cement floor and it should seperate. seen a lot of hubs on chrysler products destroyed by not doing this procudere and just trying to beat them out.
- Post n°107
Will do. I will give an update once i get everything i need. Thanks again
- Post n°108
the easyest way is to cut off all the studs as close as you can to the drum, then they will punch out, i used a small hammer and hit it with a larger hammer and the hub fell out, for some reason once the hub is parted from the drum the studs will beat out then,
- Post n°109
So am I to understand that with this conversion I am going to use my old front drum hubs? Just curious because I wasnt straight on that before.
Im driving my van just fine, but my master is back bleeding thru itself, so I need to replace it. When Ive got all the parts ready I'll just do the swap instead.
- Post n°110
yes you need your old hubs, but i think scarebird will sell you hubs, if you want to buy them,
- Post n°111
Oh, no I dont need to buy what I already have...unless mine are junk, but then I wouldnt be driving it very well. Thank you.
- Post n°112
Like jkr said, the studs are swedged. you need to use the hole saw to cut the shoulder off. If you don't, when you press or hammer them out, you will enlarge the stud hole and the new studs wont fit right. I used a grinder to cut the heads off the studs and pounded them out from the back. Either way you will need new studs.
- Post n°113
http://www.ebay.com/itm/140499382316?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
i got these they look a little shorter, the ones on there now hit the caliper on a hard turn, i guess i'll find out when they arive,
- Post n°114
A while back i read a post about a bracket that relocates the sway bar link to the top of the axle to keep it from hitting the caliper. You might find it in the files.
- Post n°115
thaks i'll check on it if these links dont take care of it,
Stoopid john- Number of posts : 265
- Post n°116
My stock links don't hit at all.
- Post n°117
i need to test drive it i blead all the brakes today, its got a nice firm pedal. what it might be i removed 2 springs to lower the front end, the top caliper plastic bolt cover hits the link when its on a hard turn, the link gives tho so i'm not going to worry about it, i think the new links i ordered should solve any problems,
- Post n°118
the brakes will be the best up grade you will do on the van. glad to hear you are done
- Post n°119
thanks dix, me too the hardest part is cutting out for the bigger MC, soon as the new sway bar links get here i can get them installed and test drive it, plus i'm still waiting for the gas tank sealer to completly dry, i'll give it another week,
- Post n°120
Glad to hear of another sucessful disc brake upgrade, you will really like how she drives.
- Post n°121
thanks Tom, i cant wait for spring and do some cruzing,,
equium- Number of posts : 107
Registration date : 2011-04-25
- Post n°122
Can anyone share the brand and/or location of any brake line kits you used in your upgrade? Was one kit enough do replace all brake lines? cost? Or a list of all the brake lines purchased? need to know info? I'm getting ready to buy more hardware for the upgrade. thanks
- Post n°123
you need a master cylinder and front brake hoses, i would replace all lines if there bad, there is a list of all the parts you'll need it comes with the scarebird brackets, or look back through this page,
- Post n°124
Dodge man were you able to buy the lines with the correct end fittings already on them ???? . I bought stock lenths and bent my own then had a local shop put the double flair on each line as I made them, buying stock lenths only came with the same fitting on each end. that is what my issue was. but still no big deal,
- Post n°125
I bought the stock lengths like dix, then bent and double flared them to fit.
