+27
dirtbag69
polosteve
rustyspoke66
Tang
61v100
BoneMan
counsel62
BillyBlaze
radicalran
jfox
tommyfogarty
KenCashion
lws67
69A108
equium
rebar
white-lightning
agentwilliams
Stoopid john
31 posters
    Scarebird brakes
    Scarebird brakes - Page 3 Empty Calipers
    Post by millwright71 Fri Jan 25, 2013 12:49 pm
    If you are using the scarebird brackets, they are designed for the standard duty calipers. IIRC there are two different calipers available for the 1500 series trucks, standard, and F44 heavy duty. Just get the standard duty ones.
    I bought mine from AutoZone and these also came with the bolt, and sleeve kit that you need Part #C552. I am in no way affiliated with AutoZone by the way, just passing on what I used.
    Last edited by millwright71 on Fri Jan 25, 2013 12:53 pm; edited 1 time in total (Reason for editing : Added information)
    Number of posts : 2036
    Scarebird brakes - Page 3 Empty Re: Scarebird brakes
    Post by dodge man Fri Jan 25, 2013 12:53 pm
    Post by dodge man Fri Jan 25, 2013 12:56 pm
    do you remember your pad part # ? thanks Tom,
    john
    Post by millwright71 Fri Jan 25, 2013 12:59 pm
    Those should be fine, about what I paid for my lifetime warranty ones without shipping. Pads were DGC368
    Post by dodge man Fri Jan 25, 2013 1:01 pm
    did you have to pay a core charge?
    Post by dodge man Fri Jan 25, 2013 1:03 pm
    i'll just get everything from auto zone since you did and everything worked good, thanks for your help Tom,,
    john
    Post by dodge man Fri Jan 25, 2013 1:56 pm
    Tom is there a right and left caliper # i looked and all they show is C552 WHATS THE PART # FOR THE OTHER SIDE?
    Post by millwright71 Fri Jan 25, 2013 7:51 pm
    C553 will be your passenger side,I did have to pay the core charge. The parts all worked really good. I had to file the opening just a tad where the caliper slides into the bracket. It seems like the coating was just a bit too thick there. I mainly did it to make changing the pads easier down the road, and to make sure the caliper would slide easily to adjust for pad wear.
    Post by dodge man Sat Jan 26, 2013 4:57 am
    thanks Tom, thats crazy way autozone doesnt say that its right or left caliper, i new they were different, lol
    Post by dodge man Tue Feb 05, 2013 10:19 am
    Scarebird brakes - Page 3 00114Scarebird brakes - Page 3 00512Scarebird brakes - Page 3 00610
    i 've heard so many different ways to install these brackets, could someone tell me if this is the right way? this is the drivers side, thanks for your help,
    Number of posts : 1148
    Post by jkr Tue Feb 05, 2013 12:24 pm
    my guess says that bracket is for the pass side. caliper usually hangs from the back side for more clearance of steering linkage. thats how i am desigining mine to work anyway..
    Post by dodge man Tue Feb 05, 2013 12:43 pm
    i think there to be faceing the front of the van, i dont know about the nut being on the inside or outside on the bracket,
    Post by millwright71 Tue Feb 05, 2013 2:15 pm
    They point to the front of the van, with the nuts facing inside. I filed my brackets so the caliper slides into it easier. Hope this helps.
    Stoopid john
    Stoopid john
    Number of posts : 265
    Post by Stoopid john Tue Feb 05, 2013 4:11 pm
    Looks good, do you polish your shocks Cool
    Post by dodge man Tue Feb 05, 2013 5:58 pm
    thanks Tom, no polish on the shocks john, just installed them
    Post by dodge man Wed Feb 06, 2013 10:50 am
    i see what you mean Tom about filing the brackets, the calipers wont slide free if you dont file them just a bit, from my pictures can you tell if i have the brackets on the right side? its the drivers side the bracket on, thanks for your help
    Post by millwright71 Wed Feb 06, 2013 11:56 am
    Looks like it is installed correctly. You will like how nice the van stops. Glad I can help out.
    Post by dodge man Wed Feb 06, 2013 12:05 pm
    ANOTHER THING TOM, THE HOSES COME WITH A BRACKET ON THEM DID YOU CUT THEM OFF ? AND DID YOU RUN THE HOSE BETWEEN THE AXLE AND TIE ROD OR OUTSIDE OF THE TIE ROD?
    Post by millwright71 Wed Feb 06, 2013 4:17 pm
    I cut the little brackets off the hoses, I cannot remember exactly how I ran the hoses, just that the driver side one was a little tight at the caliper. It had enough clearance though.
    Post by dodge man Wed Feb 06, 2013 4:44 pm
    thanks for everything Tom, i think i have all the info for now, i'm waiting on my rotors so i can finish them,
    john
    Post by millwright71 Wed Feb 06, 2013 8:03 pm
    Did you get the ARP wheel studs as well?
    Post by dodge man Thu Feb 07, 2013 7:12 am
    yes i did i have them in and the right side i need to spot weld them in, there a little loose, the left side fit great, i may not need to cut them shorter with running chrome wheels and baby moon caps, that is if the 14'' wheels fit over the calipers, may need to get some other wheels, i'm still waiting on the rotors to arive,tomorrow i'll start on the master cylinder,
    Post by millwright71 Thu Feb 07, 2013 9:29 am
    If they are loose, but won't spin, I used some loctite bearing retainer compound. It is green in color, and is made to take up spaces like that.
    Post by dodge man Thu Feb 07, 2013 9:36 am
    GOOD IDEA MIGHT BE BETTER THAN WELDING, I DONT LIKE TO PUT HEAT ON THE BEARINGS, I'LL FIND ME SOME ON EBAY,THANKS TOM
    JOHN
    Post by dodge man Thu Feb 07, 2013 9:45 am
      Current date/time is Mon Nov 25, 2024 6:41 pm
