by Army of Six Thu Mar 08, 2012 9:25 pm
thanks fellas. hopefully the motor will go in this weekend and i can button up the front end. things went well today. i was able to flip the rack and pinion and fabricate some mounts. they will work but im thinking that i will redo them to cut down on the angle to make life easier on the borgenson joints.
and here it is...the missing link..the piece that green lighted my whole build...without this discovery i would not have attempted this build. its a steering box off of a 80's Volkswagen vanagon. 1:1 ratio. Steering wheel input on the top and the output is a steering shaft back to the rack and pinion.
AND yes when you turn the steering wheel to the right the wheels turn in the right direction. lol
i cut the steering column shaft off of the old econoline steering box (about the only thing that old worn out steering box was good for) and fabricated a mount to mate up with the VW box
here i a shot of where the VW box will rest. I just started to make the brackets to mount the VW box. once that is done then all i have to do is cut the DD intermediate shaft to length and install it with the brogenson joints. and i will post pics of that later. one of my concerns was that the brake pedal would come down onto the intermediate shaft. but it cuts up underneath nicely and with plenty of clearance.
