+6
NipRing
billski
10 posters
    Aluminum Radiator
    Number of posts : 1778
    Aluminum Radiator - Page 2 Empty Re: Aluminum Radiator
    Post by m1dadio Thu Apr 19, 2012 7:23 am
    Nice job on that rad and engine install
    M1D
    NipRing
    NipRing
    Number of posts : 336
    Registration date : 2011-08-14
    Post by NipRing Thu Apr 19, 2012 9:14 am
    Number of posts : 7905
    Post by DanTheVanMan Thu Apr 19, 2012 10:03 am
    Looks and sounds good Bill!
    Take her for another spin after you reinstall the wings and belly pan. The radiator with get about 20-25% more air with them installed. What temp thermostat are you using?
    Dan
    Aluminum Radiator - Page 2 Qr_cod10
    NipRing
    NipRing
    Post by NipRing Thu Apr 19, 2012 10:20 am
    Thanks! I think it was a 180.
    And M1Dadio, the brackets came yesterday. Thank you!
    BajaCharlie
    BajaCharlie
    Number of posts : 619
    Registration date : 2010-01-07
    Post by BajaCharlie Sat Apr 21, 2012 10:42 pm
    Anybody do this on an A yet?I also dont wana modify much stuff.Where did you get if so?
    Stoopid john
    Stoopid john
    Number of posts : 265
    Post by Stoopid john Sun Apr 22, 2012 8:08 am
    NipRing
    NipRing
    Post by NipRing Wed May 02, 2012 8:14 pm
    So i finally finished it up. Putting the belly pan/wings back on.
    Aluminum Radiator - Page 2 0a79c6fe
    I put the front of the belly pan on first, let the back hang down, put the wings on, then each rear corner i used a 1 inch spacer and a 2" bolt at the back where the wing normally overlaps the belly now they're reversed but secure, like so... (sorry for the blurry pic here)
    Aluminum Radiator - Page 2 235ddee3
    And when your done it looks this way.
    Aluminum Radiator - Page 2 86ed6ca8
    Also, the front belly bolts are down tight, the back corners have longer bolts with spacers, but the bolts that are about 1/3 of the way from the front, those i only put in about half way. I used lock washers so i dont think they'll back out, but to send them in all the way would have been tough, the belly is tight to the bottom of the radiator. I thought that it might rattle or something but nope.
      Current date/time is Mon Nov 25, 2024 3:16 pm
