ok, I need to replace the radiator on my 1968 dodge A-108. I have a 340 with the cast iron 273 water pump. I also do not need to spend 50 bazillion dollars on it either. who has what?? im looking for reccomendations, testimonials.thanks dave.
Henrik
dodge A-108
i need a aluminum radiator!!!
dodge A-108- Number of posts : 67
Henrik- Number of posts : 156
Re: i need a aluminum radiator!!!
Check out the post about the fsr aluminium radiator. I need to get the same thing done.
I buy all my radiators on ebay!!!!!!!!!!! They have 3 & 4 core new ones freight free in usa- Now depending on what water inlet / outlet locations u need??????????? They build both chev & ford types-again I use the chrysler ones as they have side mount flanges on them!! I have these in my chev & ford applications> There are several companys selling them on ebay!1 heres one example- I use the Champion Brands usually!=
http://www.ebay.com/itm/1967-1968-1969-1970-Chrysler-Imperial-Aluminum-3-Row-Radiator-/291205157275?pt=Motors_Car_Truck_Parts_Accessories&hash=item43cd2e119b&vxp=mtr
others chev type = http://www.ebay.com/itm/3-ROW-ALUMINUM-RACING-RADIATOR-14-FAN-70-73-DODGE-CHARGER-PLYMOUTH-318-5-2L-V8-/381066767274?pt=Motors_Car_Truck_Parts_Accessories&hash=item58b9596baa
one I bought/chev inlet/outlets== http://www.amazon.com/Champion-CC374-Aluminum-Replacement-Radiator/dp/B00AKKK42Y?SubscriptionId=AKIAIKBZ7IH7LXTW3ARA&&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00AKKK42Y&tag=wwwbookcompar-20&ascsubtag=5476313a26a3dc355434b629
I used an Ebay aluminum GM crossflow radiator. Turned it so the tanks were top/bottom. Left the fill cap on the bottom, and used a 23LB pressure cap (on the bottom port only) then used a dodge Dakota in hose radiator cap fixture/ with a 13lb cap. Works great. And when you drain the system only take 45 seconds. The radiator was like 19x27 for something like 139.00 free shipping.
I did have to make two flange extenders, so it would bolt up.
will that e bay radiator just plain fit? in no way will I cut up my van. I need a rad that fits without modification . or at least the mods get done to the rad NOT the van. any experiences with this???Twinpilot001 wrote:I buy all my radiators on ebay!!!!!!!!!!! They have 3 & 4 core new ones freight free in usa- Now depending on what water inlet / outlet locations u need??????????? They build both chev & ford types-again I use the chrysler ones as they have side mount flanges on them!! I have these in my chev & ford applications> There are several companys selling them on ebay!1 heres one example- I use the Champion Brands usually!=
- Number of posts : 8731
look under a100 parts /links page,
everything we know works is posted /stored there.
re, radiator
ive looked at the links page and found nothing about radiatorsdix wrote:look under a100 parts /links page,
unfortunately $600 is waaaay out of my price range.probably will be a huge stumbling block to other members as well. so ,,, on to the alternatives.dodge A-108 wrote:ok, I need to replace the radiator on my 1968 dodge A-108. I have a 340 with the cast iron 273 water pump. I also do not need to spend 50 bazillion dollars on it either. who has what?? im looking for reccomendations, testimonials.thanks dave.
I can buy 3 for 600 bux -!!!!!!! Ive posted several times before -i get them 3&4 core new alunimum ones off ebay that fit chev or ford inlet / outlet positions - they even have a side Flanges to mount them with!! all are dodge/ chrysler truck/ car applications too!!!!!!
they make them for many 67-77 chrysler products!! just depends on what inlet / outlet positions u want!
I have a 1967 A100 with av-8, I would think all of the years (64-70) would all use the same size radiators? Am I right in thinking this?
