This is what I found when I was investigating why the engine had such noisy lifters.
This is what I've done:
1) removed, carb-cleaner-bathed, blew out with compressed air the rockers, pushrods and lifters.
2) removed as much sludge from rocker valley with carb cleaner, brushes and rags.
3) reassembled and ran engine with flush.
I found that I had one badly worn rocker pivot, and was able to get one from the salvage yard. Trying to figure out the zero-lash thing gradually, you know, to try to judge that the lifters are filling with oil normally. Unfortunately I am only seeing one rocker getting wet from what appears to be proper oiling...
4) I waited a couple days to change the oil, hoping that solvents in the flush may be immersing the oil pump pickup. Cheap oil, cheap filter, rocker pivot replaced, let the engine idle with the clean oil! No improvement in what I see or hear, so I did the flush again in the same way.
I had noticed that one rocker seemed to have a larger oiling hole, and contemplating drilling out the others a little larger. What do you guys think? However, I would like my next oil change to do the trick. Also, seeing oil on one rocker tells me that the pump is working (not catastrophically clogged), so I want to avoid dropping the oil pan. In my next oil change (today?), I will be adding the Rislone which is supposed to work like Marvels Mystery Oil... well adding it after I've let it run with just the new oil and filter for a bit. Just hoping the cleaning I've done will start to produce proper oiling and cleaning in inaccessible passages and journals.
