    Transmission linkage
    Rich1
    Rich1
    Number of posts : 10
    Registration date : 2015-12-23
    Transmission linkage Empty Transmission linkage
    Post by Rich1 Thu Dec 24, 2015 10:03 am
    We have a 66 dodge A100. New 318 engine, rebuilt auto trans, disc brakes on the front, ect.
    The problem that we are having is with the shifter connection at the transmission which is
    external. Does anyone have photos or can take a photo of how it is hooked up????? Have spent hours trying to figure it out. Time to ask for help. Thankx
    Number of posts : 12245
    Transmission linkage Empty Re: Transmission linkage
    Post by donivan65 Thu Dec 24, 2015 10:51 am
    Transmission linkage Dscn7422
    Transmission linkage Dscn7423
    Transmission linkage Dscn7424
    Rich1
    Rich1
    Post by Rich1 Thu Dec 24, 2015 2:07 pm
    Finally. Thank you, Thank you, Thank you. Best Christmas gift ever
    Richard
    Number of posts : 8769
    Post by dix Thu Dec 24, 2015 3:09 pm
    do you have the cable ?? also under a100 parts links i posted the cable manufacturer and the connection from the cable and the tranny
    Rich1
    Rich1
    Post by Rich1 Thu Dec 24, 2015 4:38 pm
    Thankx, I will be looking at this. We don't have the proper leaver that attaches to the transmission and we have a cable from a boat. Will this work?????
    Post by dix Fri Dec 25, 2015 7:49 am
    depends how creative you are...
    Number of posts : 3046
    Post by RodStRace Fri Dec 25, 2015 10:32 am
    Try to get the shifter all set up before you break everything in. The selector lever at the transmission MUST be in the correct position when driving to avoid damaging the transmission due to the valve body being partly in 2 positions.
    The throttle pressure (kickdown) linkage is very important on Torquefiltes! It will tear up the transmission if you drive it without it installed and adjusted properly. I am not a huge fan of Lokar, but this should show you enough to understand the reasons for this linkage.
    http://www.hotrod.com/how-to/transmission-drivetrain/1504-the-lowdown-on-stock-torqueflite-kick-down-linkage/
    I would suggest starting/breaking it in with the trans in Neutral. In Park, the front pump is not in play and the fluid level is off.
    http://www.allpar.com/mopar/transmissions/torqueflite-tom-hand.html
    There are at least 2 different A100 throttle setups; cable and linkage. Make sure the parts are correct/matched.
    There are 3 different shifters, but all should have the same 'throw' between Park and 1st.
    more info
    http://maxwedge.com/articles/transmission-diagnosis.php
    BADBADGER
    BADBADGER
    Number of posts : 246
    Post by BADBADGER Sat Jan 02, 2016 12:07 pm
    I am looking at the reply from DIX with the pictures of the transmission linkage. I have not seen a cable transmission linkage for the A100 before. Both of my Dodge service manuals show pictures of mechanical linkage but no cable linkage. would appreciate knowing what service manual this picture appears in. My service manual is for 1967.
    Post by RodStRace Sat Jan 02, 2016 3:22 pm
    mechanical trans linkage, cable or mechanical throttle linkage.
    Post by dix Sat Jan 02, 2016 3:35 pm
    the tranny pics were from donnie the governor . and not i. the 3 rd photo is correct for a 68 / 70
    the 2nd photo does appear in my 1968 manual section 21 page 35 but not sure what it is for.
    BADBADGER
    BADBADGER
    Transmission linkage Empty transmission linkage
    Post by BADBADGER Mon Jan 04, 2016 3:30 pm
    In question I asked about the mechanical trans linkage but meant the cable throttle linkage as pictured in the post. Was this cable set up on a Dodge van. Neither of my service manuals show that set up.
    Post by dix Mon Jan 04, 2016 5:13 pm
    i don't know mine was a 69 /6 before the v8 conversion
    Rich1
    Rich1
    Post by Rich1 Mon Jan 04, 2016 6:28 pm
    I don't know about the van's. We just found out ours is a 1965 Dodge A100. It had a 6 cylinder &
    we replaced it with a 318 V8. The pictures that were posted seem to match up with what we are
    trying to accomplish. The transmission is a 727. We haven' got around to hooking it up as yet but
    we will post it when we have succeeded. Wish us luck.
    Rich1
    Post by dix Tue Jan 05, 2016 3:28 am
    there is a supplier for the cable it's posted under a100 parts link
    the person building them is not selling them cheap .
      Current date/time is Sun Nov 17, 2024 3:42 am
