I'm on the hunt for an A100 slant or small block. I've been looking a gallery photos of yours. When I find a good driver . I plan to install AC. Can some of you A100 owners post pictures of your throttle linkage or cable system to the carb (six cyl and small block please) . I've seen a system from a 67 small block that has a bracket at the front of the head/ with a rod going to the carb. My worry is that an AC compressor would block the throttle rod. So I would like to see some of the other throttle control system that were used. Any photos sure would let me know of compressor/ throttle , clearance problems.
throttle linkage/cable pictures ?
- Number of posts : 8729
Thanks for the information....but I can't view it I joined yahoo a100 a week ago. But everytime I try to login I CAN"T. and don't have a text number.
Terry is a little slow in reg. I don't think he logs in every day hand in there and he will get you in. I will see what i can find but the bell crank would bolt to the head just below the drivers side valve cover, But they did have power steering on the camper models
gary h- Number of posts : 474
Throttle linkage
Good pics from Service manual,The later kickdown rod has a big loop at the Carb.
Re: throttle linkage/cable pictures ?
My 273v8 came without the factory throttle linkage, I ran a custom cable up the firewall to the back of the card linkage so that's an option as well.
kiwimopar- Number of posts : 740
Check my Gallery pics out here;
http://vintage-vans.smugmug.com/Vans/KiwiMoPar/11040212_QNhPW5#!i=832427010&k=w3MSrxF
I am running a Vintage Air A/C system, and Lokar throttle cable & pedal setup. Works great.
