Hello Everyone,
I have a 1965 G10 Sportvan and have a question. When I got the van, a previous owner swapped the 6 cylinder / 3 speed out for a small block and autotrans. Unfortunately, the original steering column with 3 speed on the tree is still in it. I would like to swap it out for an aftermarket steering column but keep the original steering gear box. Upon reviewing the parts books I got and what information is available on the internet, I can't tell if the steering shaft goes all the way from the steering wheel into the steering gear box (worm drive gear) or if I can disconnect the "column" from the steering box. I haven't pulled it apart yet to see because of weather. I'm trying to research some to determine the best approach at tackling this problem. I would appreciate any info you can give?
