    2nd Gen G van side & rear door locks
    Riconine
    Riconine
    Number of posts : 53
    Registration date : 2016-01-03
    2nd Gen G van side & rear door locks Empty 2nd Gen G van side & rear door locks
    Post by Riconine Sat Apr 16, 2016 4:37 pm
    OK maybe I'm missing something. Wouldn't be the first time.
    Is there a way to lock & unlock the side & rear doors from inside the van?
    Mine currently aren't locking at all. The key turns but the C shaped metal piece doesn't move.
    Guess I'll be disassembling those mechanisms. WD40 to the rescue! cheers
    Has anyone retro fitted a way to lock the doors from the inside?
    Thanks Guys - Luv this place - Ric Cool
    2nd Gen G van side & rear door locks Empty Re: 2nd Gen G van side & rear door locks
    Post by donivan65 Sat Apr 16, 2016 9:28 pm
    reach in the door,,,,,and see if you can move that C shaped lever up and down and WD 40 it,,,,,,the finger on the cylinders job is to lift that C lever up and down to lock and unlock the door,,,,,,,see what you got,,,,,
    2nd Gen G van side & rear door locks Repair11
    Post by donivan65 Sat Apr 16, 2016 9:30 pm
    SportVans have buttons on the inside like normal cars to work the locks,,,,
    Post by donivan65 Sat Apr 16, 2016 9:33 pm
    Riconine
    Riconine
    Post by Riconine Sun Apr 17, 2016 8:35 am
    Donivan Thank You
    You are indeed the Man. exactly the info I needed. I tried reaching in & moving the C piece, both are frozen. Oh well I've got a gallon of WD40. Twisted Evil
    Post by donivan65 Sun Apr 17, 2016 11:43 am
    that finger on the key cylinder needs to move that C lever up and down,,,,,,I think shooting some WD up in there will free it up,,,,,,
    2nd Gen G van side & rear door locks Dscn8012
    Riconine
    Riconine
    Post by Riconine Mon Apr 18, 2016 7:22 pm
    Got the lock mechanisms freed up. Now move up & down. The little finger on the rear door lock doesn't reach far enough to unlock the door. I tried bending it, may have screwed the pooch. Still working on it.,Got to get them fixed as I'm ready to panel the doors.
    Oh yeah. Figured a way to lock from the inside. Didn't take to much. I'll post pictures later.
    Thanks again Ric
    Post by donivan65 Mon Apr 18, 2016 9:16 pm
    I have seen some of those fingers with a little piece of rubber fuel hose or shrink tubing on them to give it a little more throw,,,,,,,,
    Riconine
    Riconine
    Post by Riconine Tue Apr 19, 2016 8:36 am
    Thanks good idea Donivan or maybe braze on a piece of copper tubing. Got me thinking scratch
    Riconine
    Riconine
    Post by Riconine Tue Apr 19, 2016 9:26 am
    Thought some of you might want to try this.
    1 - Drill a small pilot hole thru the inside door skin & thru the latch.
    2 - Enlarge this hole for a 1/4x20 screw
    3 - Tap the hole in the latch for the screw
    4 - Elongate the hole in the door skin down about 3/4"
    5 - Run the screw into the latch, nut it on the backside of the threaded hole
    6 - You can now lock & unlock your side door from the inside of the van by moving the screw up or down
    Happy modifying - Ric Cool
    2nd Gen G van side & rear door locks Door_m10
    Thanks to Donivan65 for the door photo
    marco_chevy
    marco_chevy
    Number of posts : 151
    Registration date : 2015-05-23
    Post by marco_chevy Mon May 23, 2016 5:58 am
    What is the name of the clip that keep the lower and upper rod in place ?  I miss one 2nd Gen G van side & rear door locks Image25
    Riconine
    Riconine
    Post by Riconine Mon May 23, 2016 10:35 am
    Named: F*+KING PIECE OF SH*T!!!
    When it flys off & disappears inside the door.Evil or Very Mad
    Ric Cool
    Post by Big W Mon May 23, 2016 8:27 pm
    We normally refer to those as Jesus clips....Cus that's usually the first word out of my mouth when it flys off inside the door or in the air landing in the grass...lol. As for the real name, I'm sure someone will know. probably a C-clip.
      Current date/time is Wed May 08, 2024 3:53 pm
