    Door lock cylinder help
    Number of posts: 389
    Registration date: 2010-12-14
    Post by StuNami on Thu Sep 08, 2011 3:51 pm
    When replacing the door lock cylinders, how do you get the part that actually turns the lock off? That part doesn't come with the new cylinders.
    ~Nami
    Re: Door lock cylinder help
    Post by Guest on Thu Sep 08, 2011 8:23 pm
    Are you talking about the tail??
    Carl
    Number of posts: 19
    Registration date: 2011-01-25
    door locks
    Post by Carl on Thu Sep 08, 2011 10:26 pm
    -you have to take the part that turns the lock from the old lock. It is held on by a small spring, so with a needle or something, -force the spring to the rear; then that part can turn 90 degrees and slides out. -have done this to 8 locks.
    Post by StuNami on Fri Sep 09, 2011 4:06 am
    Mike, Yes the tail. Carl, does the tail go back easily on the new cylinders? I've got a few from the junk yard I can pratice on I suppose.
    Thanks
    Post by Guest on Fri Sep 09, 2011 10:23 am
    The tail should go on easily
    Carl
    Number of posts: 19
    door locks
    Post by Carl on Fri Sep 09, 2011 11:29 am
    I would say the tail not go back on easily, but after you do a few you get the hang of it.
    Post by StuNami on Sat Sep 10, 2011 5:29 pm
    Thanks Guys.
    Cheers.
      Current date/time is Wed May 16, 2012 2:26 pm
