    Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder?
    redsockss
    redsockss
    Number of posts : 123
    Registration date : 2010-06-03
    Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder? Empty Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder?
    Post by redsockss Tue Jul 20, 2010 3:22 pm
    Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder.
    I'm also searching out the track that attaches to the drivers window on the bottom. I don't have a clue on where to find them. I searched a few sites with no luck.
    Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder? Empty Re: Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder?
    Post by G-Man Tue Jul 20, 2010 4:48 pm
    the outer handles are differant, inner are the same
    redsockss
    redsockss
    Post by redsockss Tue Jul 20, 2010 4:52 pm
    I'm needing the gaskets for the outside mounting of the door handles. and the lock cylinders. Does that mean the truck ones won't fit them? ANy idea on how I can find them? I looked at Brothers and no go.
    richie61
    richie61
    Number of posts : 445
    Post by richie61 Wed Jul 21, 2010 7:20 am
    My ignition switch on the dash was missing when I got mine, replaced it and took all the door locks to a locksmith and had them re-keyed for $15 each. If you are missing the whole cylinder I'm sure someone has a extra set laying around. I found this post from before on the gasket.
    https://vintage-vans.forumotion.com/g-parts-wanted-f12/outside-door-handle-gaskets-1st-gen-t14121.htm?highlight=gaskets
    Nate66
    Number of posts : 13
    Post by Nate66 Mon Aug 02, 2010 12:39 am
    redsockss wrote:I'm needing the gaskets for the outside mounting of the door handles. and the lock cylinders. Does that mean the truck ones won't fit them? ANy idea on how I can find them? I looked at Brothers and no go.
    This was posted on vcvc.org.
    Clarks Corvair has repro door handle gaskets
    large gasket #c1549 small gasket #c1550
    Side + back door gasket #c6530 lock gasket
    #c566 413-625-977
    Catalog page 229 http://www.corvair.com/gfx/229.jpg
    ChevyVanMan1
    Number of posts : 425
    Does anyone know if the door handles for the Truck is the same as a van and the door lock cylinder? Empty Door lock vs. Ignition Lock...
    Post by ChevyVanMan1 Thu Feb 10, 2011 9:10 am
    am hoping to get all mine keyed the same for simplicity. However, can't get the chrome caps off the the side/rear key mechanisms. Would like to take to a locksmith yet they are one of the few trades in DC that aren't licensed or bonded--hence they are mostly theives. Funny to have such a loophole for criminals to be in a security business. Anyway, can anybody recommend somebody I can just mail my locks and keys to for rekeying. Am told an honest locksmith will charge between $8-15 each.
    Your referral will be appreciated, thanks!!!
    ChevyVanMan1
    Post by ChevyVanMan1 Mon Feb 21, 2011 9:27 am
    As for gaskets, I'm using black oil bottle plastic. Cut them oversized with the inside holes cut, bolt them down and trim them on a really hot day in the sun. Of course, not cutting the paint under is the trick.
      Current date/time is Sat Apr 27, 2024 9:36 am
