    door cylinder lock gaskets same on a mustang trunk?
    door cylinder lock gaskets same on a mustang trunk? Empty door cylinder lock gaskets same on a mustang trunk?
    Post by Guest Mon Mar 26, 2012 2:18 pm
    i am looking for the gaskets that go between the door cylinder locks and the doors on my 63 econoline van
    i was thinking that a mustang trunk may have the same lock and could use those gaskets
    can someone tell me if this is the case or a source for the correct gaskets please
    thanks
    door cylinder lock gaskets same on a mustang trunk? Empty Re: door cylinder lock gaskets same on a mustang trunk?
    Post by Guest Sun Apr 01, 2012 2:57 am
    update
    i have been hearing that the econlines never had gaskets on the door lock cylinders. that is possibly why i cant find any gaskets
    and i dont think the early mustang is the same shape
    i dont want to put back together without something as the cylinder has already started wearing the paint and dont want a leak there
    i have left a tracing at a sign company and they are going to cut me some
    will post on the success of this
    also making outside door lever and mirror pedastal "gaskets" same way
    Post by Big W Sun Apr 01, 2012 9:32 pm
    I have never noticed any gaskets on mine, only the little key doors that swing over the tumblers to block dirt and grud from getting in there. I wonder if a person could use something like RV roof vent puddy. Just put a little bit around the lock and after it's all tightend up just wipe off the little bit that may have squished out.
    Number of posts : 1868
    Post by HandiVanMan Sun Apr 01, 2012 9:50 pm
    I have never noticed any on any Chevys either
    Post by Guest Sun Apr 01, 2012 10:03 pm
    i think you guys are right they didnt come with a gasket but i am going to make some for mine
    thanks
      Current date/time is Fri May 10, 2024 1:28 am
