All of my door locks have stopped working. Are there common replacement parts or should I take them to a locksmith?
Door locks 64 A-100
nate the skate- Number of posts: 1116
Registration date: 2008-05-19
Re: Door locks 64 A-100
A-100 door locks are the same as what was used on the other Dodge trucks of the same era.
The newer style locks (flush mount) that you can buy at the part stores will not work. I tried.
Take them to a locksmith..that's what I had to do.
- Number of posts: 5627
Registration date: 2008-05-12
Did they ever work? Otherwise it would seem that the key wore out rather than all the door lock cylinders at 1 time. If you take one cylinder out, there might be a key code stamped on it so a locksmith can make a new key for it. And could it be the linkage or locks froze up and not the key cylinders?
jkr- Number of posts: 781
Registration date: 2008-05-29
chrysler parts has a product called "dri slide". it works very well to free up door locks if they are stuck. unless the local locksmiths have new tumblers to install i don't think they will be able to do much for you either. i do door locks at work by times and the small brass tumblers do wear out. if they are worn beyond there limit by times the locksmits leave them out.you might try to remove every second one or them all. that way any key would open the doors but only you would know.
OH..I almost forgot.
Terry over on the Yahoo A-100 site had a place that sold new door locks. I don't remember the name of the place!!!
Ter' comes over on this site from time to time. Oh Ter'????
benwah- Number of posts: 1046
Location: the land of broken dreams and shattered hopes CT
Registration date: 2008-07-05
DO TELL!!! I need some too for my sportsman! they make both cargo door and drivers door?
enbro- Number of posts: 465
Registration date: 2008-05-16
I could use a set too and have no idea where to get 'em....Terry?? Hello?
There's an NOS set on Ebay right now.
http://cgi.ebay.com/ebaymotors/MOPAR-NOS-DODGE-DOOR-LOCKS-KEYS-1964-TO-68-VAN_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem270366403475QQitemZ270366403475QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I bought the NOS one on ebay....
Good News!!! found some napa AUVECO#17833 (matched pair)
