I will probably replace the distributor and coil with a modern electronic version other than that its carburetor and a mechanical fuel pump for me.
So
How do I tell what engine size it is?
Is the stock 144 or 177 enough to use in todays traffic safely?
I believe I understand correctly the 200 will bolt right up to my 3 speed manual, will the parts (carb, starter etc.) from the 144 or 177 fit on the 200?
I am not interested in a V8 or cutting up the van in anyway to put a bigger engine in it, just what fits in the stock location with the stock tranny, thanks so much in advance for your help!
