+19
Udo
Linoman
NitroAcres
Bluelemon
chate
ndjarrett
cole63
mothradeath
Ddavllc
23 posters
Build Thread for Ddavllc 66 E-Truck
Ddavllc- Number of posts : 127
Registration date : 2013-11-07
I bought this from another member of VV and i just love it. Once you get a new toy I think everyone need to make it their own and i am doing just that. It has a small block 302 and a bunch of other upgrades as you'll see from uploaded pic's.
Welcome and great looking Econo
I have been out in the garage putting new shock and leaf spring on as I am replacing the astro supremes spinner 15in wheels to a 40 year old set od American racing daisy s200 wheels that have been re-cnc-and powder coated
15x8.5 in back and 14x7 in front.. There where no issues with the 14 in front as I do have front disc brakes (d&d/wilwood).
Good to hear that your wheel choice will work!
A/R 200s were the first set of new wheels I bought new. Love the design!
Are you going to clear in the back with the 8.5s? I'm sure the E guys will want to know the offset and tire sizes.
I am trying to rebuild my wing windows. Does anyone know how to get the window from the frame???
I can only think drilling the rivets from the frame?
I removed the nut from the bottom and I can even separate the pivot point but the cant remove bottom??
econopoor- Econoline Guru
- Number of posts : 1747
Did you take out the three screws holding the frame in the door? Two on the leading edge of the door and one inside the rubber vent seal by the vent window lock.
Yes. I actually have them both on the work bench. I can't figure out how to remove them from the frame so I can replace the rubber seal.
Re: Build Thread for Ddavllc 66 E-Truck
Vent windows
I got it:cheers:
Congrats on figuring it out! Also, you couldn't have picked anyone better to design an interior than Fred, Top Notch all the way! Stunning pickup...keep the pics coming Please!
- Number of posts : 8729
nice truck... and Fred will make the inside as nice as the out side...
How about some pictures and text so the next guy can learn from you!Ddavllc wrote:I got it:cheers:
I am sorry I forgot people are really following (man that's Cool ) ok i am posting pic's as well. the bottom nut must be removed with a /2 inch wrench there is no washer remove the spring. the next washer is keyed so make sure and note the position next is a waffer washer
at this point I put penetrating oil on the shaft to clean spline so the next keyed washer would come off the rusty spline please make note of the position of the wasker to the spline first. if you dont the pic's will show you
Those washers will come off that splined shaft. They are tight and it takes some persusion to work them down. Put an open end wrench between the pointed washer and the frame, a nut on the threads to prevent damage to the threads and tap it apart with a plastic or brass hammer. A little lube wouldn't hurt.
Sorry, didn't know you were this far along in the disassembly. I was trying to figure out which rivits you were talking about.
Can't go wrong with a Fred interior. Nobody does it better. That will be the crowning touch on your beautiful truck.
mothradeath- Number of posts : 217
- Post n°19
you wouldnt happen to know where one could buy that self adhereing insulation surrounding the doghouse do you? looks like some quality stuff.
- Post n°20
http://www.ebay.com/itm/121166965442?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I got it on Ebay. it doesn't cut down on noise too much but it does cut down on heat. it also helps with ratting and make the truck feel more solid. I am planning on doing the entire inside of the truck with it this weekend. Ill post more pic's Monday.
- Post n°21
Not such a good nite in garage.......... The anti rattle strips don't install as easy as it looks. Has anyone done thiers . I ruined one and I don't want to buy a entire kit. I emailed dales mfg to see if they would sell me one... We see. Still anyone have any tricks before I ruin another?
Thanks
Thanks
- Post n°22
I ordered new window channels today. 65.00 worth of mistake. Hey Fred Whats the trick???
rebuilt vent window and reinstalled into passenger door. Started on dog house today amazingly there is a load of stuff hanging in the front cowl (brake fluid res, msd, ect,ect)
had the windshield reinstalled.
- Post n°23
- Post n°24
- Post n°25
