White Whale
    318 questions
    White Whale
    White Whale
    Number of posts : 19
    Registration date : 2012-06-22
    318 questions  Empty 318 questions
    Post by White Whale Thu Jun 28, 2012 12:00 pm
    My van had a 318 installed in it, I don't know much about it, the previous owner installed a electronic distributer and there a lot of wires that don't correspond with the manual. Does any know where i can find information about this engine where it came out of ? there are a couple of parts on the engine that i have no idea what the are.[img]318 questions  P6280010[/img]
    #1 is attached below the engine
    [img]318 questions  P6280012[/img]
    #2 is attached to the side of the engine
    [img]318 questions  P6280013[/img]
    #3 is attached behind the coolant reservoir but is not attached to anything.
    [img]318 questions  P6280015[/img]
    #4 Not sure if this is a sensor [img]318 questions  P6280016[/img]
    General picture of everything
    The oil gauge and temp have never worked and i'm not sure if that's a compatibility issue with 318. any advice would help greatly
    Number of posts : 8732
    318 questions  Empty Re: 318 questions
    Post by dix Thu Jun 28, 2012 4:23 pm
    photo # 1 is a electronic voltage regulator it should be in the dog house or under the dash. photo # 2 is the starter relay. it should be in the dog house. photo # 3 is the same as photo # 1 photo # 4 is a vacume to the carb. on a newer engine. the last photo. the wiring job is amateur at best. . you need to go on e-bay and buy a service book for your year van, about $30.00 but it will not address the electronic conversion. give us some time to find the info you need.. or when Donnievan chimes in he is top notch. . i'm sure he will be in on this one.. all and all this can be cleaned up. BUT were else did the previous owner wire..
    White Whale
    White Whale
    Post by White Whale Fri Jun 29, 2012 3:58 pm
    I have the service manual with the electronic diagram and I can get as far as the engine in how everything comes together. The rest of the car is ok a couple of dome light issues but thats fine.
    Post by dix Fri Jun 29, 2012 7:01 pm
    let us know if you need help.
    Number of posts : 1319
    Post by 67a 100 pickup Fri Jun 29, 2012 7:23 pm
    Dix is right... the starter relay and ballast are supposed to be mounted to the rear dog house panel. I'll take a pic for you tomorrow.
    Post by 67a 100 pickup Sat Jun 30, 2012 10:45 am
    Here is where they are supposed to be mounted, the left lower side of the rear dog house panel.
    318 questions  Dsc_0112
    318 questions  Dsc_0113
    white-lightning
    white-lightning
    Number of posts : 237
    Post by white-lightning Sat Jun 30, 2012 8:26 pm
    #4 is an egr valve.
    Post by dix Sun Jul 01, 2012 3:39 am
    the egr valve was not used in the a100 engines. i'm thinking it could be left alone.
    Post by donivan65 Sun Jul 01, 2012 9:12 am
    Well that newer stuff goes under the hood and since you don't have a hood, you have to put it in the doghouse or on the engine,,,,,,
    318 questions  Dodge_30
    318 questions  Dodge_31
    318 questions  Dodge_32
    Post by donivan65 Sun Jul 01, 2012 3:14 pm
    Those EGR systems had a lot of parts to them,,,,,,,however,,,,,I would remove the EGR valve and block it off with a plate or piece of metal under it to keep the intake passage from sucking air out of the exhaust passage and causing the engine to run rough,,,,those valves are known to leak through the diaphrams and seat inside them,,,,so block off those 2 holes in the manifold,,,,,,
    318 questions  Egr110
    318 questions  Egr211
    Post by dix Sun Jul 01, 2012 3:29 pm
    that's a good point donievan you are 100 percent correct. and I was wrong. I knew you would would chime in.......
    Post by donivan65 Sun Jul 01, 2012 4:53 pm
    You got it right,,,,,it aint bothering nothing,,,,,but when they start leaking, it is hard to figure out why the engine runs bad,,,,the valve will look good from the outside and inside,,,the sign would be engine vacuum reads a little lower than normal,,,,,so might as well just block it off and be safe.......
    Number of posts : 956
    Post by slowflapper Tue Jul 03, 2012 10:44 am
    Holy Franken Wiring Batman.
    I have a '65 w/273v8 but the below should apply yours as well (but verify).
    The oil and temp gauges not working may be that they don't have power. Pull the instrument cluster out of the dash a little (after disconnecting the battery) and see if there is a jumper wire from the fuel gauge to the oil/temp. IIRC the dash voltage limiter is inside the fuel gauge, it steps 12v down to about 5v and powers all the gauges in the cluster.
    On my van the starter relay and ballast resistor are on the dog house rear panel. There should be an oil pressure sending unit screwed into your block just beside the distributor (where your relay now sits).
    Here's a picture of mine showing all three pieces, my oil unit is right by the coil with a wire for the dummy light and a hard line for the mechanical gauge:
    318 questions  Distrib-20101002-00056
    here's the wiring diagram for a 65 with a 273 v8:
    318 questions  A100%2520wiring%25201
    318 questions  A100%2520wiring%25202
    you can get the bigger version if you need it from the "picture gallery" link in my forum signature.
    White Whale
    White Whale
    Post by White Whale Tue Jul 03, 2012 2:42 pm
    Oh man this is great, thanks everyone. I'll keep you posted on how it turns out.
    Post by dix Tue Jul 03, 2012 4:31 pm
      Current date/time is Sun May 19, 2024 5:28 pm
