+5
gary h
69
SnarkyPoet
Braindead
9 posters
    A few Questions.
    Braindead
    Braindead
    Number of posts : 12
    Registration date : 2024-02-18
    A few Questions. Empty A few Questions.
    Post by Braindead Sun Feb 18, 2024 9:17 pm
    Hey all, new here and hopeful for a little help with my 19?? Dodge A100.
    I'm not fully sure of the year, I read through a few forums about reading the Vin# and understanding it, but I'm still not sure about the year.
    I understood that the first part 20  marks it as a wagon.
    Third, number  8  is for the cylinders.
    But then the numbers repeat  208, then 2377.
    This is the same number on the info plate on top of the driver-side well. and matches the number stamped on the frame in the passenger side wheel well.
    This van sat in a barn out here in Cali, so there were only a few rusty areas, plus a few dents.
    But it was free, and I couldn't pass it up.
    Number of posts : 917
    A few Questions. Empty same
    Post by wylee Mon Feb 19, 2024 5:50 am
    awsome score, and welcome. post some pics of your new toy
    Braindead
    Braindead
    A few Questions. Empty Re: A few Questions.
    Post by Braindead Mon Feb 19, 2024 10:51 am
    A few Questions. Img_8311
    A few Questions. Img_8312
    A few Questions. Img_8310
    She's a little ugly, but I see a fun diamond in the rough.
    Braindead
    Braindead
    Post by Braindead Mon Feb 19, 2024 10:53 am
    A few Questions. Img_8313
    A few Questions. Img_8315
    A few Questions. Img_8314
    Some damage on lower corners and rust along gutter.
    Braindead
    Braindead
    Post by Braindead Mon Feb 19, 2024 11:01 am
    A few Questions. Img_8316
    A few Questions. Img_8317
    Still lots of stuff (junk) to go through in the back. parts and parts and parts.
    Engin had a plastic cover on it, and after some cleaning of the dust and mouse beans off of everything, it looked better. Though I think the motor was switched at some point. Also, this one has a throttle cable that runs from the gas pedal to the engine.
    Single resovor brake master cylinder, so not fully sure of the year or if this little las is a frankin truck.
    SnarkyPoet
    SnarkyPoet
    Number of posts : 174
    Registration date : 2009-12-22
    Post by SnarkyPoet Mon Feb 19, 2024 2:46 pm
    Based on the dash and interior color, fancy dash trim, and vin number... it looks like a late `65 or early `66 A100 Custom Sportsman which would have had a 273 in it.
    Braindead
    Braindead
    Post by Braindead Mon Feb 19, 2024 9:04 pm
    Will have to check engine numbers and see what is in there,
    Just have to find the numbers next.
    Post by wylee Tue Feb 20, 2024 3:13 am
    awsome project there!!
    69
    69
    Number of posts : 434
    Post by 69 Tue Feb 20, 2024 5:08 am
    Very good! Save it. Fun-fun-fun. Smile
    Sportsman -> true.
    Vin -> off the 1969 coding scheme as follows; might be different for earlier yrs:
    20 -> Model Code = A100 Wagon
    8 -> No of Cyl = 8
    2 -> Assembly Plant = Warren Truck (Heavy Duty; note: a 1 would be Warren Truck w/o HD)
    xxxxxx -> six digit sequence number
    It might make sense to get a parts book (for reference and schematics) and a service manual.
    Braindead
    Braindead
    Post by Braindead Tue Feb 20, 2024 5:54 pm
    Where would the engine ID # be?
    And how would I tell which engine is which?
    gary h
    gary h
    Number of posts : 474
    Post by gary h Tue Feb 20, 2024 7:47 pm
    Van looks to have been customized many moons ago. cheers
    Post by wylee Wed Feb 21, 2024 2:54 am
    that is some fancy dash trim, never seen that before, very cool !!!
    Number of posts : 1558
    Post by OutofSight Wed Feb 21, 2024 7:20 am
    I put that same sportsman trim in my ‘65.
    Number of posts : 8729
    Post by dix Wed Feb 21, 2024 4:13 pm
    welcome to vintage vans , lot of good people and good info here.
    Dix..
    69
    Post by 69 Thu Feb 22, 2024 8:07 am
    Braindead wrote:Where would the engine ID # be?
    On the block itself (pass/driv side, don't remember right now) in pretty big letters casted into the block you'll find some numbers to identify the type of engine.
    Engine ID should be on the driver side upfront stamped into the block, just below the cyl heads. It should be a machined surface there.
    BUT you can't tell if the engine is numbers matching to the van - no VIN there.
    66CampWagon
    66CampWagon
    Number of posts : 8
    Registration date : 2021-05-07
    Post by 66CampWagon Tue Feb 27, 2024 7:29 am
    I agree with SnarkyPoet - 65-66 custom sportsman based on dash trim, metallic tan interior, and outside trim on the midline. It took me a long time to find the 273 number stamped on the front of the block, just below the head. It's on the side that you took the picture. The block casting numbers on mine did not give the block size, but the date stamp was 66. Also, 273's have adjustable mechanical lifters that are apparent when the valve cover is off. nice find!
    Braindead
    Braindead
    Post by Braindead Thu Feb 29, 2024 8:30 pm
    Sooo a little update so far.
    Found a good driver-side front glass tiny little chip in it, but should be able to get it fixed (filled)
    I found the shift linkage in the back; now I just need to figure out which one connects to where.
    Found all but one D for the front Dodge and the custom sportsman badges.
    All the inside door handles and window crank handles, along with the washer bottle.
    Plus, a couple of boxes of misc parts and such, including some vintage hotrod parts, two vintage stirring wheels, one classic green metal flake vinal/rubber grip style, and a real wood custom style.
    The interior is rust-free, with no holes where they shouldn't be.
    And found out the pop-out step works fine.
    Though now I have a nice bruise on my shin from it.
    66CampWagon likes this post
    66CampWagon
    66CampWagon
    Number of posts : 8
    Post by 66CampWagon Fri Mar 01, 2024 8:26 am
    The first of many shin bruises to come on the magic step. BTW, there are two versions of the "D" letter. the middle one is shaped to match the nose crease.
    Braindead
    Braindead
    Post by Braindead Fri Mar 01, 2024 9:47 am
    Sadly, I have a flat one.
    And does anyone have the diagram for the three on the tree shift set up?
    Post by donivan65 Sat Mar 02, 2024 2:35 pm
    Heres a start,,,,,,,,,
    A few Questions. Img_2050
    A few Questions. Img_2051
    A few Questions. Img_2052
    Braindead
    Braindead
    Post by Braindead Sun Mar 03, 2024 8:44 am
    Thank you very much, I now know I need to find hardened washers and the linkage stops. Hopefully there in one of these boxes.
    Is there info for which linkage bar goes to which shift link?
    Oh seems the previous owner was planning on making it automatic, found the complete dash-mounted shifter assembly and shift cable in one of the many milk creates in the van.
    Post by dix Sun Mar 03, 2024 3:50 pm
    the correct cable has value, although there is a company in Detroit area where i bought mine maybe 12 to 15 years ago
    Post by donivan65 Sun Mar 03, 2024 7:30 pm
    If you just pull the shift lever down, thats 3rd gear and that should be the bottom lever down on the column,,,,,and the rod should go to the back lever on the trans,,,,,,
    Braindead
    Braindead
    Post by Braindead Sat Mar 09, 2024 8:53 am
    This is the automatic shifter I found in one of the boxes in the back of the van. Looks pretty complete. (I think)
    A few Questions. Img_8320
    A few Questions. Img_8319
    A few Questions. Img_8318
    Braindead
    Braindead
    Post by Braindead Sat Mar 09, 2024 8:54 am
    A few Questions. Img_8321
    A few Questions. Img_8322
    A few Questions. Img_8323
      Current date/time is Fri Apr 26, 2024 11:37 pm
