So I took a look at this situation here. I have to repair the outer sheetmetal, as it got chewed up and a couple tears / cracks. Also figured out that there is a bracket that the wiper motor bolts to also extends along the skin of the van to support the wiper arm mounts too... I thought they just secured against the outer skin. Anyway, the passenger-side of this bracket is broken off at the hole where the wiper linkage secures to. So I have to get one out of my donor as well as a small section of the sheet metal.
So Demondog, I have to try to get out there and wrench and cut! I guess I might need to get a cordless drill with a cutting disc to get a body section out, huh? Do you have one? I don't. I do have some tin snips...
Thanks,
