Does anyone know the actual resistance of the resistance wire that is between the water temperature sender unit and the actual gauge?
https://i.servimg.com/u/f44/19/88/21/89/thermo10.jpg
kiwimopar likes this post
gmytych likes this post
69 wrote:Possible thought, but no other Mopar of those years has a resistance wire.
And, to be honest - if the temp gauge goes beyond "hot" you better shut off the engine anyway....
gmytych and kiwimopar like this post
dodtorcito wrote:69 wrote:Possible thought, but no other Mopar of those years has a resistance wire.
Think in that scenario:
You drive in a hot summer day and your temp gauge indicates correctly.
You stop your car for lunch. The temp of the engine rises over the normal limits and stay this way during long time.
All this time the temp sender is sensing passing his limit during this long time and fails burning and a close the circuit to ground with ZERO ohms.
When you return to your car after the coffe, you start the car and the grounded temp sensor makes your gauge moves the needle to its maximun way. After a few seconds, your gauge is melted.
If you would have a small resistance wire into the sender cable, your gauge would indicates a little lower than its maximun way and no melted gauge.
Then you stop the car and see what´s happening.
Enjoy.
