    rear body section
    garagedoordennis
    garagedoordennis
    Number of posts : 45
    Registration date : 2013-04-30
    rear body section Empty rear body section
    Post by garagedoordennis Thu Jul 11, 2019 3:46 am
    looking for the rear panel behind drivers side rear wheel cut just under gas cap. Anyone have a van there cutting for parts ?
    gfleduc
    gfleduc
    Number of posts : 376
    rear body section Empty Re: rear body section
    Post by gfleduc Thu Jul 11, 2019 7:21 pm
    garagedoordennis
    garagedoordennis
    Post by garagedoordennis Fri Jul 12, 2019 3:45 am
    that lower section is part of it but need it to be all the way to wheel opening
    gfleduc
    gfleduc
    rear body section Empty Sheet metal
    Post by gfleduc Fri Jul 12, 2019 3:14 pm
    I believe he has front to rear - three different pieces
    Number of posts : 1048
    Post by VANagain Mon Jul 22, 2019 3:02 pm
    Dennis, will this orange piece help you out? It doesn't go to the wheel well nor does it go to the hinge. This skin was detached from the floor and filler neck shield that it was spotwelded to:
    rear body section Metal_11
    rear body section Metal_12
    rear body section Vanaga10
    Then there's this whole back end. It has the subframe and floor still attached:
    rear body section Metal_16
    rear body section Metal_17
    If no one wants the entire back end, I could cut off the corner you need:
    rear body section Metal_15
    rear body section Metal_14
    rear body section Metal_13
    gfleduc
    gfleduc
    Post by gfleduc Mon Jul 22, 2019 3:12 pm
    Dennis,
    For inside the cargo bay- I have a flat pattern for the fuel tunnel if you need that. I can send you a file, print it out to size, Lay it out on you sheet metal, cut & bend to form upper rounded edges.
      Current date/time is Thu Nov 21, 2024 8:33 pm
