Hi all, I'm looking to do a couple of improvements to my van and I want to make sure I'm on the right track. I would like to switch over to the new 24 gallon tank that Vansauto is producing. I see on his website that he also sells sending units for the 1st gen's.
I'm running a TBI fuel injected motor so what I'm thinking is that I would have to plug the fuel pickup on the stock sending unit and buy a universal fuel pump with the fuel supply, return and vent lines on the mounting bracket or whatever you call it. Then I would have to saw a hole in the top of the tank to mount the pump to. Am I on the right track?
I'm also going to switch out my pancake style AC compressor for a Sanden and I want to try something different for a throttle cable. It's hard to complain about having AC but that pancake style compressor is loud! For the throttle cable, I used a Morse style and it has enough resistance that when I push the gas, it doesn't happen real smooth. I was looking at the Lokar throttle cables which look more like a go cart kind of cable. Anyone have any input?
