    pictures needed of stock heater location on a 66 van
    tikiwagon
    tikiwagon
    Number of posts : 55
    Registration date : 2012-10-22
    pictures needed of stock heater location on a 66 van Empty pictures needed of stock heater location on a 66 van
    Post by tikiwagon Tue Jan 30, 2018 2:05 pm
    Hi i need some pictures or diagrams of the  stock heater location on a 66 van as mine has been removed while the last owner fitted some Chrysler headlamps but cant see any mounts or screw holes as where exactly it goes, Ihave attached some pics of what i have Thanks
    pictures needed of stock heater location on a 66 van P1110252_zpssxhrclxj
    pictures needed of stock heater location on a 66 van P1110255_zpsavxmgzvm
    pictures needed of stock heater location on a 66 van P1110256_zpsfsxonhm9
    pictures needed of stock heater location on a 66 van P1110257_zpsi7ieinsf
    pictures needed of stock heater location on a 66 van P1110258_zpspfwgtfxv
    Wolfster
    Wolfster
    Number of posts : 140
    Registration date : 2016-08-27
    pictures needed of stock heater location on a 66 van Empty Re: pictures needed of stock heater location on a 66 van
    Post by Wolfster Tue Jan 30, 2018 3:41 pm
    4th and 5th pic show the passenger side air box.  That mounts over the fresh air intake next to the passenger side headlamp housing.  Once you get that attached there, the other mounts and where they hook up to will make a little more sense.
    Wolfster
    Wolfster
    Post by Wolfster Tue Jan 30, 2018 3:49 pm
    Was the square tubing added by the previous owner when he did his modifications? Sure don't remember seeing that on any I've taken apart.
    The more I look at the pics, it looks like he kinda messed up the front sheet metal where the air box mounts. And, you'll need another air box for the driver side.
    You're other option is to go to a Vintage Air heater defroster. You'll have to make a bracket or plate to mount it to. Mine is welded to the floor, though I've seen some that a plate is mounted from air opening to air opening.
    Number of posts : 2087
    Post by Seth G Tue Jan 30, 2018 9:25 pm
    What is going on on the drivers side headlight intake there?
    tikiwagon
    tikiwagon
    Post by tikiwagon Wed Jan 31, 2018 12:11 am
    the last owner fitted 65 Chrysler headlights  for which he cut out a big hole where the stock lights would have mounted and because they sit further back into the cab area he put a bar across the back to mount them, i can remove most of this though
    Wolfster
    Wolfster
    Post by Wolfster Wed Jan 31, 2018 3:52 am
    Wow. And the bad part of it is, you're in the UK, so parts may be difficult to find.
    tikiwagon
    tikiwagon
    Post by tikiwagon Wed Jan 31, 2018 5:51 am
    Yes thats true, Also why i woul like to put back the stock heater if i can as we need it withe cold over here
    jifop
    jifop
    Number of posts : 65
    Registration date : 2016-05-22
    Post by jifop Thu Feb 01, 2018 11:50 pm
    Where are you based tikiwagon? There might be someone localish who can show you theirs!
    jifop
    jifop
    Post by jifop Thu Feb 01, 2018 11:56 pm
    Also if you are in Facebook check out www.earlyeconolines.co.uk
    tikiwagon
    tikiwagon
    Post by tikiwagon Fri Feb 02, 2018 1:43 am
    chhers for the help, I am in Poole Dorset , if i had a few pictures of the location under the dash and if it has any mounting brackets(mine has none) that would be a great help
    jifop
    jifop
    Post by jifop Fri Feb 02, 2018 2:01 am
    Cool, I'm up in Hertfordshire.
    It doesn't mount to the dash at all it hangs off the front panel.
    Basically if you had the original headlights you'd remove the chrome headlight surround and you will see a bracket above and below the headlight with 2 screws in each, also a screw either side of the heater inlet, these 6 screws hold the later heater box in.
    This picture shows the screws https://drive.google.com/open?id=1YnX4-mV3a_TBRmfPpqffbgVMMxDDQVQr
    Does that help?
    tikiwagon
    tikiwagon
    Post by tikiwagon Fri Feb 02, 2018 3:19 am
    Yes it does help but my headlamp surround has been cut further so there is no mounting on that side(I guessed it was where you said i was )looks like i will have to make some sort of mounting bracket up for it
    Thanks
    jifop
    jifop
    Post by jifop Fri Feb 02, 2018 3:28 am
    Ah that's annoying, what lights have you got fitted now?
    Shouldn't be too hard to fabricate mounts in the original position if you've got back to stock lights.
    tikiwagon
    tikiwagon
    Post by tikiwagon Fri Feb 02, 2018 4:47 am
    It's got 65 Chrysler lights which look really good but they are a big unit and sit a lot further back than a stock light so there is no going back now
    jifop
    jifop
    Post by jifop Fri Feb 02, 2018 4:59 am
    Gotcha! Car builder solutions have some aftermarket heaters that would probably work well if you get stuck.
    Would like to see a picture of that!
    Number of posts : 2016
    Post by Barnabas Sat Feb 10, 2018 11:33 am
    I do not have any pics of the heater installed, but here is an exploded view of the heater.
    1965-1967 Heater
    Post by Barnabas Sat Feb 10, 2018 11:46 am
    Here is a picture of a 1965-1967 heater installed. The defroster hose near the accelerator pedal is not connected properly.
    pictures needed of stock heater location on a 66 van Heater_1965-67
    Wolfster
    Wolfster
    Post by Wolfster Sat Feb 10, 2018 1:22 pm
    Barnabas wrote:Here is a picture of a 1965-1967 heater installed.  The defroster hose near the accelerator pedal is not connected properly.
    What?!? I thought that was to keep your foot warm and your vent window defrosted. lol
    tikiwagon
    tikiwagon
    Post by tikiwagon Sat Feb 10, 2018 3:14 pm
    Thanks for the picture , I will have to fabricate a couple of mounts to make mine fit
      Current date/time is Tue Jan 14, 2025 4:03 am
