Last edited by sweetvan on Sat Apr 20, 2019 9:57 am; edited 1 time in total (Reason for editing : Calculated lbs.)
+17
Dan Scully
Falconvan
gary h
Jaydub
busman78
lired
polosteve
rustytoolss
whalemstr
21 posters
New from Germany '69 A100 pickup
sweetvan- Number of posts : 242
Registration date : 2013-12-16
- Post n°226
Re: New from Germany '69 A100 pickup
How many pounds is that? 1540kg X 2.2 lbs/kg = 3,388. lbs.
69- Number of posts : 434
- Post n°227
According to my app thats 3395 lb.
Gas Tank almost half full.
- Post n°228
Light as a feather!
- Post n°229
Isn't it? I told my friend with a 74 Coronet, also 318 in it and loooong axle, that I'm going to burn him down - his weight was 3946 lbs.
- Post n°230
OK, so, we actually didn't test it. But we had a great trip to the German Mopar Nationals. Just some vanny impressions here. I'd think, 50% of all German A100's were around . Almost all body options at hand (PU, A100 panel + window, A108 panel), except the A108 window van. Actually, a friend has one, but it wasn't ready yet. We even have a Corey Camper around. And a Pickup converted for the strip. All those not being present at the Nationals.
dix and kiwimopar like this post
- Post n°231
Awesome, thanks for sharing.
dix likes this post
- Post n°232
Way cool!!!
dix likes this post
- Post n°233
Did the x-mas shopping (tree) today with the little truck. And visited his big brothers afterwards. It's a RAM seller with at least 50 RAMs on sale, right around the corner. That's quite a lot here in Germany, where you almost get yelled at with anything bigger than a Prius... I don't like Greta
kiwimopar likes this post
UKvanner- Number of posts : 1
Registration date : 2019-02-01
- Post n°234
Love the pickup ,just what i was looking for to partner my A108 display van 318/727,no luck so ended up with a '65 Econoline 5 window pup.
My A108 has power steering (Armstrong I think from memory ) which did leak a little on the ram, managed to cure it with additive,which swells the seals.
Econoline Pup is '65 170 c.i. 6 pot + 3 speed manual, not ideal, trying tuning it up first 6 branch & weber carb , before I resort to major engine gearbox swap.
- Post n°235
Welcome UK vanner. Post some pics of our Vans/Vanups.
- Post n°236
Just today. Little meet with my friend Tom who bought the A108 which was stored just about 1000ft away from my home without me knowing it (previously owned by the guy I got to know at the junk yard - see above in my thread.)
Tom showed his van lately here on vintage vans.
- Post n°237
Lockdown, but not locked down.
Got my biennial roadworthiness test passed yesterday without deficiency.
Although, a couple hints: king pins starting to get loose, right front wheel bearing a little loose, brake line beginning corrosion (I didn't notice that, though) and the front brake with left being 25% less than right. Didn't notice that during driving, truck didn't wander to the right, as one would expect.
Oh, and the front leaf spring rear hanger was almost gone, I would say. It was only 2 years old, but that one needs to be replaced.
I had a great day, the ingenieurs at the test station had fun and the weather was good.
Yeah!
Yeah!
- Post n°238
Congrats! And now you have somethings to keep you busy and take your mind off the lockdown...stay safe and hopefully we'll get back to normal sooner than later.
- Post n°239
Thx vanny, although, I have too much projects keeping me busy at this time. Work load is more than hefty (haven't worked that much my whole life), then I need to get the big camper back on the road (after various issues I'm now waiting for a new water pump. And the Ford LTD CV still needs a lot of TLC). And I get a new place for the camper, the garage move will be quite some work, too...
- Post n°240
Long time no write. Short story: my pickup just runs and runs and runs.
Today, we went to the local electronics shop and got something you NEED a truck...
savage and kiwimopar like this post
- Post n°241
Another round of no problems - he just runs... Bought some oil filters, change 1/3 of my car park already. A100 is easiest, although you need to remove the passenger seat and at least 6 screws to partially open the doghouse ...
Due to the LeBaron addition, the A100 has to sleep next to the Camper this winter. But today some work had to be done and oil change made sense afterwards.
- Post n°242
And again - a day trip (approx. 300 mls) with no problems. It just runs.
Eventually got the bumper from Jeff (last picture - that was almost 2 years since we started with buying, transport and such), so today I was able to pick it up. Very happy, now the odd rear bumper can be replaced with the right one.
Thanks to Jeff, Carsten, Olli & Kris.
Anyone a source for the plastic inserts for license plate mount? And the 2 licence plate-lights?
jkr and kiwimopar like this post
jkr- Number of posts : 1148
- Post n°243
certainly a bit of an odyssey to get the transaction complete but it happened and i am thankful for that. guess now i can go get that cash from the bank for reinvestment in some other mopar project. good to hear from you Jens.....
- Post n°244
Yes, bumper exactly as described - and Odysseus had an easy time, I guess, compared to our transaction
It worked out, that's all what counts. I am very happy, Jeff. Thanks again.
jkr likes this post
- Post n°245
It's too bad the chains on the tailgate are damaging the rear corners of your pickup. They can be covered with a vinyl sock or something to soften them and reduce the damage. I've also heard of people installing Ford tailgate latches to replace the chains.
Hope you are keeping your A100 inside now.
- Post n°246
I tried some socks on it, but it they just suck - looks awfull.
Although some thin clear coating may be possible. E.g. silicone, polyester or such. I'll have to evaluate that.
On the other hand, the overall "used look" is quite matching to the "damaged" rear corners. On pictures, you never see the real look of it.
The truck is of course always garaged and with a car cover, except for meetings (or going to the dumpster - with good weather only, of course .
Recently, returning from a meeting, we got caught in a short but severe thunderstorm. The front windows are not sealing perfectly (no glue/silicone etc. used). As it is usually only driven with good weather, I'll leave it like that.
My Charger leaks at the exact same location (lower window corners), there I'd like to fix it, but with all the chrome trim it is quite some work.
Currently, I'm redoing the brakes on my new daily (79 LeBaron), with pistons and all.... THey were locking at our holiday trip recently.
- Post n°247
Long time, no write.
The little one just runs. Still rough at cold start and I could still enhance the carb settings, but time is kind of a problem.
Anyway. Today, I got another two years passing local roadworthiness test.
Some things still on the To-Do list:
* make brake lines nice (cleaning, some copper paste on it to protect them)
* change the rear bumper to an original one (which I already have)
* fabricate some sheet metal to put the spare tire on the bed
* have all leaf springs properly protected (as they get rusty)
Well, early retirement looms around the corner (end of next year), so I guess, I'll take care of those things then
vanny likes this post
- Post n°248
Great to hear from you! I've got a little longer to retire...3 years but it gives me something to look forward to! Time just seems to fly by so hopefully it won't be too long... Sounds like you have a plan and the truck looks good already anyway!
Keep on Vannin!!!
Keep on Vannin!!!
gmytych likes this post
- Post n°249
Did a trip to a close-to-local car meet (approx. 90 miles oneway). Cool ride, but I should fix the valve cover gasket. Whenever I do more than 2800rpm, it leaks like hell... Below that, it's quite ok.
Truck did fine, meet was great!
Photos -> click me
But first, automatic satellite antenna on the Camper, together with lots of smaller projects on that one... The To Do is extensive...
Photos -> click me
savage and dix like this post
- Post n°250
Meanwhile, I got pre-retired (no more work, some less money). Time's available, but weather is bad (too cold still).
Anyway, A100 has some issues holding idle and off-idle is somewhat off, while driving in general seems fine.
Had a chance to check all those basics yesterday. Compression is 130-155 psi cold, ok. Timing mark on damper is perfect. Plugs are ok'ish (relatively new). Carb is bad - overflowing during compression test (approx. only 50 turns of crankshaft). Needle & Seat are ok, perhaps debris got flushed while removing needle? Anyway, seems fixed, but will check on fuel pressure anyway later on.
Distributor is different. Mechanical advance does not come back to zero-position - so, timing is likely off / erratic. Cleaned the area around the distributor and saw the mess inside the distributor; perhaps 55 years of negligence...
Completely cleaned the whole thing (fully disassembled), looks nice now (after some hours cleaning zen-meditation), only to learn afterwards, that the shaft is no more straight (did not check beforehand...).
Now I'm shooting for the progression ignition (on its way, hopefully no trouble and fast delivery).
The oil problem seems solved for the moment by using those shaped washers below the head cover screws to better spread pressure to the old covers.
And 3 of the other 4 cars are awaiting service and repairs as well (SL -> water cooler broken, Charger -> Front Balljoints, Camper -> adjustment of rear main shaft, various camping projects).
Weather definetely needs to get better....
