I'm doing some wiring going to an electronic voltage regulator. As I was looking over my factory service manual (wiring) I see that the power goes from the ign SW to the fuse panel and through a FUSE then to the regulator. Although I did not pull the fuse. It looks like the wiring diagram says fuse 61A. The fuse does not look to be over 25A.
Has anyone had any problems with the fuse in the charging system ?
I have NEVER seen a fuse between the ING SW to the regulator. Is this something mopar did in there trucks?
Back to my electronic reg. Should I still get my IGN power from that same FUSED regulator power lead ?
Sure could use some input. I would like to get thing done under the dash. Thanks guys
