    Torque spec
    dulcimerbob
    dulcimerbob
    Number of posts : 115
    Torque spec Empty Torque spec
    Post by dulcimerbob Fri Mar 14, 2014 10:01 pm
    Need torque spec for front wheel spindle nut on e van . Not in my manual
    Thanks
    Number of posts : 1747
    Torque spec Empty Re: Torque spec
    Post by econopoor Sat Mar 15, 2014 6:16 am
    It's not really a torque issue. It's something you feel. Tighten the nut until the hub won't turn then back it off until you can spin it with two fingers. You do this before you adjust the brakes so the hub spins freely. Once set then adjust your brakes. The cotter pin keeps the nut from backing off.
    dulcimerbob
    dulcimerbob
    Post by dulcimerbob Sat Mar 15, 2014 6:22 am
    Thanks Duane,
    Been a long time since I worked on drum brakes.
      Current date/time is Sun Nov 17, 2024 12:46 pm
