    Exhaust Manifold torque
    Exhaust Manifold torque Empty Exhaust Manifold torque
    Post by Guest Fri Mar 23, 2012 10:23 am
    Hello
    I'm about to replace my exhaust manifold on my 170 E-van if I can can get the bolts out! My question is what is the torque when replacing the new bolts?
    Thanks Rally72
    tatewman
    tatewman
    Number of posts : 45
    Registration date : 2012-02-15
    Exhaust Manifold torque Empty Re: Exhaust Manifold torque
    Post by tatewman Fri Mar 23, 2012 11:19 am
    the shop manual says 13-18 ft.lbs. for a 170 or 144
    Parts & Labor likes this post
    Number of posts : 466
    Post by Sy Hollinshead Sat Mar 24, 2012 2:43 am
    I have a spare engine in my garage. I tried to remove the manifold and 3 of the bolts sheared, so be careful....!!!
    Post by Guest Sat Mar 24, 2012 12:19 pm
    Rally 72
    Torque to 13-18 lbs.
    Just a tip, torque the bolts, run it to get to normal temp, let it cool and torque them again. I found out the hard way (replacing the gasket twice) that the bolts need to be retorqued once it heats and cools.
    Not that the gaskets are expensive but it's a pain in the A$$ doing this twice.
    Lucky
      Current date/time is Sun Nov 17, 2024 12:38 pm
