Bear with me as I'm currently learning all the vocab.
So got my clutch equalizing bracket & ball-stud problem fixed, thanks to the man-beast know as Victor. When ever the clutch pedal is pressed, there is this winding/whirring sound emanating from the bell-housing area? (see image below). When I release the clutch pedal, the sound goes away. The previous owner had this issue too, and I noticed it prior to the pivot joint sheering off. I'm tinkering with finding the optimal length for the clutch de-activating pin...(what goes into the divot into the arm that protrudes from the bell housing? see pic below). I noticed when it was shorter the whirring was louder & more pronounced, however as I lengthened it, it changed pitch and isn't as loud....
Any thoughts?
How do you check transmission fluid ( i was wondering if i'm low)
Any thoughts?
