Normally my vans temp gauge would steadily climb to about 220-230 at highway speeds, only dropping below 200 when running at slower speeds below 60mph. I have been running the stock shroud with a heavy duty 15" flex fan that has thick steel main blades with smaller stainless flex blades attached.
I installed the FSR yesterday, test drove it some, and put it to the real test today down the interstate (70 miles round trip in 90+ degree heat, speeds up to 80-90mph)
The temp at idle for prolonmged periods was about 195, once underway at up to 55mph temp was at about 172-180 (w/180 thermostat) I could watch the temps rise up to around 180 and then they would drop a little as the thermostat was functioning.
Today the same thing, yet on the highway at higher speeds the temp ran between 182-190 degrees the whole time, this at runs of about 80-90+ mph for extended periods. This in air temps of about 70 in the morning and 90+ in the afternoon. Also, I am using no shroud. Needless to say, I am impressed. My cooling issues are no more! Wish I would have done this sooner. What follows are the pictures I took as I installed the radiator, along with the supplies I used and various modifications I did to fit it.
Lorin
