+12
64chevy
16 posters
    The Blue No Door
    Number of posts : 12248
    The Blue No Door - Page 5 Empty Re: The Blue No Door
    Post by donivan65 Tue Aug 11, 2009 11:10 pm
    The Blue No Door - Page 5 Th_blueflashers
    Post by donivan65 Wed Aug 12, 2009 2:02 pm
    There is electricity in the air,,,,,at least in the No Door,,,,,nice piece of copper tubing in the fuse box,,,,(wonder how many amps it is),,,,,That hazard switch looks pretty ugly to be next to the blower switch,,,,so it will probably go on the bottom or under the dash,,,,,,might as well put an electric fan on it,,,,,we wouldn't want it overheating while trying to get back on Vanishes's trailer,,,,,
    The Blue No Door - Page 5 Nodoor37
    The Blue No Door - Page 5 Nodoor38
    The Blue No Door - Page 5 Nodoor39
    The Blue No Door - Page 5 Nodoor40
    Number of posts : 1048
    Post by VANagain Tue Aug 18, 2009 10:51 pm
    Here's a photo showing where the 4 way flasher unit is mounted on Rob's Sportvan. In the middle of that panel you seem to notice it hanging out below less.
    The Blue No Door - Page 5 Flashe16
    It is still pretty visible when seen from lower:
    The Blue No Door - Page 5 Flashe17
    Number of posts : 1389
    Post by wideload Wed Aug 19, 2009 5:50 pm
    My flasher switch is mounted just like Vanagain's. If it had the knob on it, it would pull toward the floor. Can anyone tell me what pieces I'm missing?
    The Blue No Door - Page 5 100_3213
    The Blue No Door - Page 5 100_3214
    Post by Vanish Wed Aug 19, 2009 5:53 pm
    Don when you pull it on dose the knob Light up or flash as well ????
    Post by donivan65 Wed Aug 19, 2009 6:43 pm
    Thats where I put it, Wideload,,,,,,you need a 1445 bulb and a red knob that screws on it,,,,,,,,and it flashes when you pull the knob to turn the 4 ways on,,,,,,,,
    The Blue No Door - Page 5 Nodoor48
    Post by wideload Thu Aug 20, 2009 10:12 am
    Now I understand. I installed a bulb and pulled the switch to the on position and everything worked perfect.
    All I need is the red knob. Anyone have any ideas for a replacement?????????
    Post by G-Man Thu Aug 20, 2009 11:41 am
    Did that option come on 64's???? I don't see anything like that
    Post by VANagain Thu Aug 20, 2009 11:50 pm
    Here's a never-installed NOS flasher from 63-64 on eBay:
    http://cgi.ebay.com/ebaymotors/1963-1964-NOS-4-WAY-FLASHER_W0QQitemZ180398484817QQcmdZViewItemQQptZLH_DefaultDomain_100?hash=item2a00966d51&_trksid=p4506.c0.m245#ht_500wt_948
    A real bargain at $525, because they often sell for over $600! Razz
    Post by Vanish Fri Aug 21, 2009 12:17 am
    WOW ... For the first time ever .. I feel Like a got a Deal on something !!!!!!!!!!!!!!!!!!!!!!!!!!!
    Number of posts : 7905
    Post by DanTheVanMan Fri Aug 21, 2009 5:33 am
    Bill,
    That is sooooo scary!!! affraid
    The Blue No Door - Page 5 Qr_cod10
    Post by wideload Fri Aug 21, 2009 5:37 am
    I better take mine off and lock it up somewhere !!!!!!!!
    Post by G-Man Fri Aug 21, 2009 8:08 am
    For that money I could live without one
    Post by donivan65 Fri Aug 21, 2009 9:00 am
    That one is for an Impala,,,,,,but the 64-66 Chevy Malibu, Chevy ll , El Camino, Pick ups, Corvette and Corvair, used the same turn signal switch on the Chevy Vans which have the same connectors on it.
    Number of posts : 1651
    Post by Scott Fri Aug 21, 2009 10:08 am
    I better get my Credit Card out before somebody else snatches that baby..
    Bet I can get those missing directions for as little as $300.
    Post by donivan65 Sat Oct 03, 2009 11:59 pm
    And look,,,,,,another bunch of parts show up,,,,,,Volt, Oil and Temp gauges with senders,,,,,turn signal switch,,,,,,,rear cargo lights,,,,,
    The Blue No Door - Page 5 Cruisi47
    The Blue No Door - Page 5 Nodoor52
    The Blue No Door - Page 5 Nodoor53
    The Blue No Door - Page 5 Nodoor54
    Number of posts : 922
    Post by wylee Sun Oct 04, 2009 4:15 am
    nice. im doing the same with gauges, what a pain trying to hook them up.
    Post by G-Man Sun Oct 04, 2009 5:24 am
    Now those are back-up lights!!!!
    Post by donivan65 Sun Oct 04, 2009 10:32 am
    That wiring can be harder than it needs to be if you don't have a plan for it. I ran 2 wires down by the gas pedal and back to the temp and oil senders. I ran 6 wires to ground under the dash for the 3 gauges and 3 back lights. I ran the 3 hot wires with an inline fuse to the Ignition Unfused terminal on the fuse box,,,,,,I ran the backlight wire to the terminal on the Panel light fuse. That whole fuse comes from the dimmer section on the headlight fuse. I ran a wire up through the channel above the drivers window all the way back and down past the left rear tail light through the fuel sender grommet to the rear lights. And I found why there was a piece of copper tubing instead of a tail light fuse,,,,,,the right rear tail light wire that goes inside the channel over the rear doors was burnt from being pinched by a metal clip that holds it into place,,,,,,now that is something that we need to check on,,,,,,,
    Post by donivan65 Thu Oct 08, 2009 3:45 pm
    So Vanish says he likes uncluttered dashes,,,,,,,WELL,,,,,,,,,I got a new blade in my air saw and a hunk of metal on an old metal filing cabinet,,,,,so lets see if we can do a little clean up on the Blue No Door.......
    The Blue No Door - Page 5 Th_NoDash
    Post by wideload Thu Oct 08, 2009 6:23 pm
    Looks good Don !!!!!!!! Now where is the radio going to go? Got to have tunes when cruising.
    Post by Vanish Thu Oct 08, 2009 9:38 pm
    Thanks Don The Dash Looks Good ........ I Love it ......... Mike yep we gotta figure out were the Radio Go's But that Cleans up the dash so Much I just cant believe how Good That Looks ......... one Day it will have a console of some kind But the dash just looks so simple and Clean That way ....
    Post by donivan65 Thu Oct 08, 2009 11:11 pm
    The Blue No Door - Page 5 Nodoor57
    Post by wylee Fri Oct 09, 2009 3:47 am
    nice. what a diff.
    Post by Vanish Fri Oct 09, 2009 6:30 am
    The Blue No Door - Page 5 Nodoor58
    Just want to Thank Don again ..... Looks Great..... This was a combo of Ideas from the show me your Dash Topick..... Thanks to XJAMESX AND gregw98 .... AND OF COURSE DONIVAN65 FOR PUTTING IT ALL TOGEATHER ...................
      Current date/time is Tue Nov 26, 2024 6:10 am
