eric67vanpkup
    Leaf Springs
    eric67vanpkup
    eric67vanpkup
    Number of posts : 85
    Registration date : 2010-12-07
    Leaf Springs Empty Leaf Springs
    Post by eric67vanpkup Wed May 11, 2011 4:06 pm
    I am currently overhauling my front leaf springs. I am stripping and wire wheeling all the loose stuff off. I discovered that all of the plastic pads between the leafs are either gone or completely gone. I was wondering if anybody has run into this problem. And also where or what I could use that will replace the pads.
    Eric. MS
    Leaf Springs Empty Re: Leaf Springs
    Post by Vanish Wed May 11, 2011 4:48 pm
    I was wondering ... do the springs have round indentions on the end of the springs ????? because if they do .. the round inserts are still available ...
    eric67vanpkup
    eric67vanpkup
    Post by eric67vanpkup Wed May 11, 2011 5:52 pm
    There are some that have the round indenting and some that doesn't. I have got both. I an running a set of rear springs I got a set off of a 66 super van. It has the round indentions on the shackle end of the spring. I am putting my original front ones back on the truck. Which has the square pads.
    Eric. MS
    Number of posts : 2067
    Post by sasktrini Thu May 12, 2011 12:15 pm
    I can't remember if it was in here, or in one of the Yahoo Econoline groups where someone restored the leaf springs and those inserts... can't remember what they used. Hopefully this will tweak someone's memory.
    Post by Big W Thu May 12, 2011 6:48 pm
    Hey Corey..Just got of the phone with my brother, who found a roll of Teflon that He cut into strips that look like a skinny I-Beam. He took the stack apart and put strips in between each leaf the full length. He said it made a world of difference in the ride of his F-150 crew cab. Problem is he bought it off a friend here is S'toon and was not sure where He had got it from. My guess Winicot springs might have it. Price unknown. Also might need "new" larger spring clamps to hold leafs together,because the leaf stack will get a little thicker once you put it all together(thickness of each strip of teflon 1/16" per piece) . I hope this helps, and if I find it first I will let you no where and how much.
    Number of posts : 466
    Post by Sy Hollinshead Thu May 12, 2011 11:17 pm
    Number of posts : 1747
    Post by econopoor Fri May 13, 2011 4:25 am
    Eric,
    I met a fellow the other day that can help you. He runs St. Louis Spring. He told me has bushings, U bolts, springs, anything you might need. You can call him at 314 533 2132.
    Jim Christian
    Shop Foreman
    St. Louis Spring Co.
    3126 Samuel Shepard Dr.
    St. Louis MO 63103
    www.stlouisspring.com
    Post by sasktrini Fri May 13, 2011 11:56 am
    That's the one I was thinking of, Sy! Thanks! We can get that stuff here, Big W?
    eric67vanpkup
    eric67vanpkup
    Post by eric67vanpkup Sat Jun 18, 2011 1:15 am
      Current date/time is Sat Jan 18, 2025 8:11 pm
