    A100 air cleaner on the 318
    Hamilton
    Hamilton
    Number of posts : 95
    Registration date : 2010-07-06
    A100 air cleaner on the 318 Empty A100 air cleaner on the 318
    Post by Hamilton Wed Jul 07, 2010 4:13 pm
    I have already addressed this lil question, but thought I'd make it it's own topic in case any other newbies were curious and needed more info too....
    but i measured the distance from the top lip of the carb to the lid, now you have to subtract about 2" of foam and the X bracket that hangs from the lid of the housing.
    A100 air cleaner on the 318 Ac1
    so looks like my cleaner can only be about 3" tall....does this seem too small?
    what are you guys running?
    thanks!
    Number of posts : 1319
    A100 air cleaner on the 318 Empty Re: A100 air cleaner on the 318
    Post by 67a 100 pickup Wed Jul 07, 2010 4:26 pm
    My stock one has 4 threads through the king nut and with the cover it is about 2 3/4" on your tape. Unless you are planning on someone sitting on the dog house 2" foam is over kill. If you have a scrap piece of foil backed foam I'd try it first to see how it will handle the heat by the exhaust manifolds. I went with the thermotec so I still have room for headers when my Y-pipe rusts out. The muffler shop wanted $300. to custom make me one and I can get headers a lot cheaper than that.
    Hamilton
    Hamilton
    Post by Hamilton Wed Jul 07, 2010 6:04 pm
    yeah that 2" foam is the stock stuff, pretty ratty....planning on the themotec too....thanks!
    Number of posts : 1148
    Post by jkr Wed Jul 07, 2010 7:26 pm
    stock type air cleaner for your carb drops down around the carb to give a bit more room. any 318 air cleaner for a carter bbd carb should fit. i would look into checking the fuel inlet of your carb cause your pics show a lot of fuel leakage. there should be a copper washer at the fitting that does require frequent tightning and or replacement in your case.
    Hamilton
    Hamilton
    Post by Hamilton Thu Jul 08, 2010 3:19 am
    good call jkr, I will look for that cleaner....and yes, a new fuel inlet is in order....
    thanks!!
    Number of posts : 923
    Post by wylee Thu Jul 08, 2010 4:08 am
    try and find a mopar six clinder air breather. there smaller .
    Post by Guest Thu Jul 22, 2010 4:50 pm
    i have a slant six air breather from a super six(*with bbd carb), i've seen you have that bbd carter 2 barils, ithat air brather wont fit in my van, its too large( i have a /6, would it fit on a 318 in a dog house??? really cheap......and its nice too
    Hamilton
    Hamilton
    Post by Hamilton Thu Jul 22, 2010 5:29 pm
    I found this one at Napa and it's a good fit, but I hope it's not too small to choke the carb!!
    A100 air cleaner on the 318 Aircleaner
    Hamilton
    Hamilton
    Post by Hamilton Mon Jul 26, 2010 12:59 pm
    I've fired the van up a couple of times after it's been sitting a few days and it seems I have to lift this air cleaner off to get the van to fire!? Is this cleaner too small? Could it be choking the carb?
    Hamilton
    Hamilton
    Post by Hamilton Sat Aug 21, 2010 11:40 am
    this was not a fun project but I finally made it work! I used napa for the air cleaner, the mounting plate for it to rest on and the hose from the valve cover. Now all I needed was a spacer to lift the air cleaner away from the vaccuum but not too high, to hinder closing the lid! Found a spacer for a turbo booster (?) on a new car that was the right diameter at Oreilleys. (item 8147 $5.99) I had to cut it down to about 3/4" tall, but seems to work!
    A100 air cleaner on the 318 Aircleaner-1
    69 a 100
    69 a 100
    Number of posts : 142
    Registration date : 2009-01-03
    Post by 69 a 100 Sun Aug 29, 2010 7:49 pm
    i had a 14 x 2 eldebrok air cleaner (found at advanced) but it got hit when i closed the dog house lid so now i just dont use one for now, not until the new motor goes in anyway
      Current date/time is Sat Jan 25, 2025 1:37 pm
