Ok, dumb question time.... I just got a 68' 318 without an air cleaner, is this supposed to have an oil bath air cleaner or the plain old paper type??
68' 318 air cleaner
68' 318 air cleaner
Re: 68' 318 air cleaner
Either one. The oil bath type was "extra equipment" aka optional. I prefer the paper type myself.
ive got several oil bath filters somewhere,.... if your intrested and want one its FREE
Is the oil bath filter the one that came on it in 68? And does it matter if I put a regular edelbrock paper filter setup on my 318
Nope..doesn't matter. If you're running a 2bbl. carburetor the Edelbrock air cleaner won't fit. 4bbl. is no problem.
Figures.... back to looking for a 2 bbl setup then.... We passed a "junk yard" on the way home that is down by the OH boarder and my son want to go poke around there on Saturday, maybe we can find a stock 2 bbl setup then.
they do make an adapter to keep your 2bl and put an aftermarket chrome 4 bl air cleaner. try your local speed shop
I did not know that. Learn something everyday.
Duane...a 318 air cleaner off of a car or truck should work, but you may have to trim a bit off of the air horn to get it to fit in the dog house.
how i found out i was replacing the oil bath air cleaner with an aftermarket one.
Good thing we figured out how to type on a computer when the weather is to crappy to be in the garage, we find out all kinds of GOOD stuff.
yup ill be in trouble when the garage has heat, the only time id be in the house is to use the tolit and shower!
wylee- Number of posts : 917
i think 68 had paper, oil bath was like in the 50's,
Im pretty sure I ve got the paper element one from my old 66 with a 318 2bl. I know I ve still got the manifold and carb. I ll check tomorrow if you want.
- Number of posts : 8726
mine is a 69 and it has a oil bath if you need it let me know ..dix.....
