My '64 had a 200" Sprint 6 installed by the previous owner from a Mustang. He had to trim the stock air filter housing to fit it within the dog house. It works but looks funky. I'd like to replace it with a custom chrome model but what do I do about the PCV hose? Also, any recommendations for something that fits a 1 barrel carb?
Air Cleaner
Air Cleaner
Old Skool- Econoline Guru
- Number of posts : 1306
Re: Air Cleaner
Does that mean you have the 200 in there??? it sounds like you do???
I am working on a conversion for a person right now, using the RBS carb upgrade, and a 240 gas pedal and throttle cable setup. It makes clearance for the header issues, as well as upgrade to use the 240 cable, which I JUST HAPPEN to make and sell ( just got an order in) ~~~~ anyways, some ideas to throw at you, with yours. The best thing we can do on ours is to supply fresh COLD air, and I have a customer with built cross flow using a remote filter and supplying fresh cold air at the same time, using an aluminum turbo cover for his 4 bbl Holley on a cross flow, I am thinking it may be an idea for our 1 bbl setups???? as I am not too impressed with all the little tiny air cleaners I have seen sucking in hot air??? The PCV valve can work either on an aluminum adapter carb base, the ones with out the hot water setup!!! I have four of those adapters here, one is the smaller tapered unit and the other three are the full 1 3/4" units (no bell crank stud types)
vic
vic
vic
vic
Re: Air Cleaner
Vic,
You make a good point about a small air cleaner sucking in hot air, and a remote filter w/intake sounds like a good idea. However my fabrication skills might be challenged by this. I would be interested in learning more about what you might be able to work up for this application.
You kind of lost me on the PCV valve issue. My mechanical skills & knowledge are all self taught - some out of necessity and some out of curiousity. Unless I've done it before, or have step by step directions, I'm at a distinct disadvantage. One of the things I like with these old vehicles is their basic simplicity, which works well with my skill set.
Tx,
Jeff
Tx,
Jeff
Re: Air Cleaner
the cold air intake is simple. Anyone can install one in half and hour. I have one on my 200 ci motor. All the parts are available on ebay including the bonnet. On a one barrel you will need to cut a base plate out of aluminum or something 5 1/8" in diameter so the bonnet can fit on it and a hole in the center the size of your carbs throat ,no big deal.
Re: Air Cleaner
Mike,,, That looks PERFECT,,,, didn't look too hard to do, but that looks real good and solves a lot of problems.
vic
vic
Re: Air Cleaner
Try a pressure cooker, worked for this guy:
