+50
VanninBlaino
mrclean
Bear
organ grinder
Rick's 66 Chevy Van
Oldsmobubble
Kris64
A100Sportsman
HOTRODVAN
Sebastien1988
GMC-BURB
badnova
sonnygable
mo_1040
Wookee
LiveWire64
Hangtime
gotavan
gp70
Hemi A-100
wacko
54 posters
    Project "G"
    Project "G" - Page 22 Empty Re: Project "G"
    Post by G-Man Tue Jan 10, 2012 4:23 pm
    Got the Cool it in the doghouse, can't believe how much more solid it seems with it in there. Will be using something on the walls and ceiling like VH did for sure now.
    Project "G" - Page 22 00319
    [url=https://servimg.com/view/13722/1590
    089]Project "G" - Page 22 00419[/url]
    Small thing redid the battery door and on the 64 and GP's van. paint and new gasket
    Project "G" - Page 22 00230
    Project "G" - Page 22 00130
    Post by Digz Tue Jan 10, 2012 6:18 pm
    It all looks good !! Is that barrier a peel&stick then ?
    Post by G-Man Tue Jan 10, 2012 6:21 pm
    Yes Joe it's peel and stick (very sticky)
    Number of posts : 2067
    Post by sasktrini Tue Jan 10, 2012 10:01 pm
    Good job! I like it all!
    Bear
    Bear
    Number of posts : 849
    Post by Bear Wed Jan 11, 2012 7:06 am
    g man where can i get that d/h liner at ?
    Post by G-Man Wed Jan 11, 2012 7:12 am
    http://www.thermotec.com/
    I have used this before also on the 69, I'll warn you it not cheap. It's heavy duty and heavy. Bet it added 15-20lbs to the doghouse and took away any tinny sound it had
    Post by Twinpilot001 Wed Jan 11, 2012 7:32 am
    New gasket for battery cover is available from=??
    Post by G-Man Wed Jan 11, 2012 3:19 pm
    That are not stock gaskets, they are thicker but work. I got them from a local Marine boat part store
    VanninBlaino
    VanninBlaino
    Number of posts : 361
    Post by VanninBlaino Fri Jan 13, 2012 6:06 pm
    Do you have gauges done yet? I'd like to see a picture of it, or what your plans are.
    Post by G-Man Fri Jan 13, 2012 7:40 pm
    Have to re do the dash before they go in, still quite a bit of bodywork to do. Can't seem to find a body guy who can stick with it.
    Number of posts : 823
    Post by mbasaraba Tue Jan 31, 2012 11:54 am
    If you dont mind me asking, how are you going to mount your gauges?
    Thought something all bright polished like this would be cool. The dimensions are not correct, I was just playing around, but we could get the dimensions from your gauges and then get a better fit in the dash.
    Was just an idea...
    Project "G" - Page 22 Cluste10
    Post by mbasaraba Tue Jan 31, 2012 11:58 am
    Could get some nice Stainless button heads to mount it in 6-8 places around the edges.
    I have some nice .100" thick Aluminum sheets I picked up, or that same .063 I am making the crosses out of. Either way, would be pretty slick.
    Post by G-Man Tue Jan 31, 2012 1:08 pm
    Sorry already brought a billit bezel for them, if I didn't already have it I would have you make something
    Post by mbasaraba Tue Jan 31, 2012 2:27 pm
    I had planned on getting that gauge set for my 64, think I will use a similar design. :-)
    Post by G-Man Thu Feb 09, 2012 12:15 pm
    Well this year trying to not be all over the place on the 64. Before anything else gets done it will be running. Right now working on that, like this whole project nothing has been easy. Putting in the Lokar shifter, but had to order a longer cable. Lokar gas pedal also needed a cable. Fuel pump what could be easier than that. Have to cut the top bracket on the air bags so there clearence and had to order a 90 fitting to make room so it won't be to close to the air bag itself. Been to the parts store also daily getting little stuff, and have made 3 orders to Summit. All this being said it has been a good week for the 64. I have got more done this week than I have the last 6 months. I will post pic's once most of this is done
    Post by Digz Thu Feb 09, 2012 2:13 pm
    Sometimes I think we end up spending more in gas than on the parts with all the trial and error and getting those needed little things ,,LOL So any gain is good !! Looking to forward to hearing that engine Bark !
    Post by G-Man Mon Feb 13, 2012 2:31 pm
    Cable nightmares Mad Shifter cable at the trans makes the shifter hard to shift. The gas pedal cable you have to push way to hard for a gas pedal. May have to for for some stock 2nd gen linkage and scrap the whole idea for the gas pedal. This week isn't starting out so good. Going to call Lokar Tuesday to see if I can save them
    Post by mbasaraba Mon Feb 13, 2012 7:00 pm
    What kind of cable? Thought of using a thick push/pull type? I got 5 of them I believe. Bought them for my gokart builds and they were left over.
    Post by G-Man Mon Feb 13, 2012 7:16 pm
    They are thick, billski has the same set-up and his works. Going to try to check out his shifter next weekend. The pedal is a lokar pedal with a 10 foot cable. May put this back to stock
    Post by sasktrini Mon Feb 13, 2012 10:03 pm
    You'll figure it out.
    Post by G-Man Thu Feb 23, 2012 4:24 pm
    Well still plugging away at it. Nothing has been easy, gas pedal linkage is done and got the throttle clips to replace the worn out ones. Trans cooler is in, but came with 1/2 barbs??? Had to order some 3/8 ones that just came in today. Still have to get the shifter cable working better. I'll get some pic's once a little more is done
    Post by mbasaraba Thu Feb 23, 2012 4:39 pm
    Got one of your lights boxed up bro! I really hope you like it!
    Post by G-Man Thu Feb 23, 2012 6:18 pm
    Matt making me some custom interior lights, will post some pic's when I get them, I can tell you they are Bad A$$
    Number of posts : 8769
    Post by dix Sun Feb 26, 2012 2:31 pm
    Chris are they going in the 64 or the 70.???
    Post by dix Sun Feb 26, 2012 2:38 pm
    Chris there is a place in detroit that made my tranny cable http://imperialservices.net/
      Current date/time is Thu Nov 14, 2024 5:34 pm
