    column shifter noise
    column shifter noise Empty column shifter noise
    Post by Guest Fri Sep 04, 2009 5:49 pm
    ARGH, my shifter always made a screeching noise when shifting and now it's getting really bad and loud.
    I've almost lost my hearing today.
    I've tried squirting some turbine oil on the end but to no avail.
    It's making me crazeeeeeeeee! bounce
    Number of posts : 1383
    column shifter noise Empty Re: column shifter noise
    Post by BILLS66 Fri Sep 04, 2009 6:21 pm
    Maybe a louder stereo would help? Bill
    Post by donivan65 Fri Sep 04, 2009 7:58 pm
    It could be the rods rubbing under the floor,,,,,, you can disconnect the rods at the bottom of the steering column and see if the noise is still there,,,
    Post by Guest Sat Sep 05, 2009 7:21 am
    It most likely is the rods rubbing in the holes in the frame. They should have nylon inserts from the factory but are gone by now. You can use PVC pipe to make new inserts and quiet things right down.
    Dennis in Oregon
    Post by donivan65 Sat Sep 05, 2009 10:00 pm
    This is how I fix Chevy shift rods when they rub the guides. I use that plastic insulation wrap,,,,,,
    column shifter noise Repair62
    Post by Guest Sat Sep 05, 2009 10:25 pm
    Thanks, good ideas Smile
    My stereo is waiting to get installed but I have no idea where to put the speakers (oval 5x3)
    mothradeath
    mothradeath
    Number of posts : 217
    Post by mothradeath Wed Sep 16, 2009 12:41 am
    check out and see if its rubbing at the top column brace that holds the column directly to the dash. it has two carriage bolts and loosening them you can move the entire column side to side. i had a crazy noise and it was an easy fix. i dont know what the name of this part is called by my old lady calls it the soap dish tray and i think its funny so i call it the same. i bet thats where its coming from.
    Hangtime
    Hangtime
    Number of posts : 64
    Registration date : 2008-09-11
    Post by Hangtime Wed Sep 23, 2009 9:14 pm
    Yes, you need a louder stereo, try adding an amp. My rod knock went away immediately after I installed my stereo. But now I have a blue smoke problem.
      Current date/time is Fri Apr 26, 2024 9:40 am
