My shifter has a lot of play in the Magic Bus...3 speed manual... My 61 truck is much tighter. Before I disasemble it is there a bushing I can order? I looked in Macs catalogue and there was nothing listed.. Id appreciate any help.. ideas ..schematics? Im assuming that it is loose down near the steering box where the shift linkage hooks up. It appears that the connections where the rods hook to the column have bushings/washers and are tight enough...same goes for where it attathches to the transmission.
Thanks...
Thanks...
