    HEATER HOSES IN HEATER ASSEMBLY
    gary h
    gary h
    Number of posts : 474
    HEATER HOSES IN HEATER ASSEMBLY Empty HEATER HOSES IN HEATER ASSEMBLY
    Post by gary h Sun Oct 16, 2022 10:06 am
    I want to replace the Two short pieces of heater hose located in the Front heater,
    They probably are original. Do i have to remove the Heater assy. or anyone have any tips ? Thanks in advance. cheers
    69
    69
    Number of posts : 434
    HEATER HOSES IN HEATER ASSEMBLY Empty Re: HEATER HOSES IN HEATER ASSEMBLY
    Post by 69 Sun Oct 16, 2022 12:01 pm
    You mean the heater below the radio? Those hoses are quite long - passing all the way to the waterpump/intake manifold. It's a pain to replace them, routing all the way back. But the heater can stay in place.
    If you mean the tubes coming from the heater inside down to the grille, for those you need to remove the heater.
    Edit: my heater has two tubes going through the footwell to the grill, and the heater assy looks pretty original.
    gmytych likes this post
    gary h
    gary h
    Post by gary h Sun Oct 16, 2022 7:21 pm
    Yes, Heater below radio. There are two short pieces of heater hose (about 4'' Long) inside the Heater Box from the Heater core. They don't leak but the thought of 55 year old heater hose is something i want to replace. I am doing a Coolant change and all my other hoses have been replaced fairly recently. So this is the time to get to those Ancient hoses.
    Thanks for the reply. cheers
    kiwimopar likes this post
    69
    69
    Post by 69 Tue Oct 18, 2022 12:57 pm
    Uhh, I just took a slight glance *inside* the box years ago. Couldn't tell off my ageing grey matter, if there are hoses or tubing only.
    Number of posts : 1558
    Post by OutofSight Wed Oct 19, 2022 9:40 am
    I just rebuilt my heater, and used a kit that had all the rubber and gaskets. It is 5/8” heater hose.
    What I need now is the proper ducting for the defrost vents scratch
    gmytych, kiwimopar and gary h like this post
    gary h
    gary h
    Post by gary h Fri Oct 21, 2022 6:21 pm
    Yes,DMT has the Kit with gaskets and those two 3" pieces of heater hose w/clamps. I saw a Link but it disappeared.
    Post by OutofSight Fri Oct 21, 2022 7:03 pm
    Found the duct work from Dorman, fits perfectly.
    Dan Scully
    Dan Scully
    Number of posts : 254
    Post by Dan Scully Thu Dec 21, 2023 9:54 pm
    HEATER HOSES IN HEATER ASSEMBLY 84e8dd10
    kiwimopar, gary h, sweetvan and 69 like this post
      Current date/time is Sun Apr 28, 2024 12:23 am
