    Clutch assembly connection (Maybe you can post a pic of your assembly?)
    Oldpro
    Oldpro
    Number of posts : 28
    Registration date : 2009-03-16
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  Empty Clutch assembly connection (Maybe you can post a pic of your assembly?)
    Post by Oldpro Mon Aug 13, 2012 1:36 pm
    Ok, I've got the new clutch in and trans reattached, but now I can't remember how to attach the rod from the clutch peddle to that linkage piece in between the clutch housing and that rod.
    I have the same problem with the other side of that linkage piece; there's that threaded rod with the eye hole thing on the end, and I don't know how it connects to the throw-out bearing arm.
    I REALLY want my van back on the road, and this is the last step! Even though my description could probably use some work, try to help a young man out here.
    Pics of another 66 dodge undercarriage of that assembly would be nice.
    Number of posts : 3046
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  Empty Re: Clutch assembly connection (Maybe you can post a pic of your assembly?)
    Post by RodStRace Mon Aug 13, 2012 4:04 pm
    Went out and took shots from the 66 /6 3 speed out back. There are a bunch of big red ants right where I needed to lie down, so they are quick!!!
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  IMG_1838
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  IMG_1839
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  IMG_1840
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  IMG_1841
    Post by RodStRace Mon Aug 13, 2012 7:19 pm
    Here are a couple more that you asked for.
    The ants have settled down for the night...
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  IMG_1842
     Clutch assembly connection (Maybe you can post a pic of your assembly?)  IMG_1843
      Current date/time is Thu May 02, 2024 12:13 pm
